Old 08-23-2009, 09:27 AM   #1
sr240noob
sr240noob is an unknown quantity at this point
Clutch going bad?
So i am just finishing up my swap and am now working out the few bugs it had/has. I am now having a clutch issue. I Bled the system pretty well, untill there were no more bubbles in the bleed tube. My problem is that when i push the clutch in it feels great but when i go to take off or after shifting gears, when letting the clutch out it doesnt engauge untill the peddle is almost all the way out. The engine has about 42xxx miles so im wondering if i need a new clutch? or if i didnt bleed the system properly or what. Any suggestions would be greatly appreciated.
sr240noob is offline   Reply With Quote
Old 08-23-2009, 09:33 AM   #2
Zachsta
Zachsta's Avatar
Zachsta is an unknown quantity at this point
Is it a stock clutch?
Zachsta is offline   Reply With Quote
Old 08-23-2009, 11:29 AM   #3
sr240noob
i believe so. Im not to sure. But im gonna say yes to that. As stated before it shifts great and doesnt grind anty gears it just doesnt grab till peddel is almost all the way out.
Old 08-23-2009, 01:37 PM   #4
reactor
reactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nice
Adjust the pedal pushrod length.
reactor is offline   Reply With Quote
Old 08-26-2009, 12:54 PM   #5
240sxjohny
240sxjohny is an unknown quantity at this point
You should also check the master cylinder and see if the clutch is worn out but im sure its not the clutch it has to be that
240sxjohny is offline   Reply With Quote
Old 08-26-2009, 07:09 PM   #6
sr240noob
Ok so i just adjust the rod on the back of he peddal? I didnt think to do that. Would i shorten or extend the length of the rod? Also the whole setup besides clutch is brand new.( master and slave cylinder, and steel braided hose)
