09-19-2009, 11:36 PM | #1 |
Close to RB20DET OR RB25DET...But...
Ok so like the title says, close to getting either. Well more like ready for the RB20 but might just get the RB25 instead.
Question though. 1. For a car that is going to be a DD and maybe start some drifting, should i get the 25? Or would the RB20 be enough? I am not really looking to get extreme numbers, maybe try for 300 plus to the wheels? Or untill i feel satisfied with my butt dyno lol. I've searched as much as i could by also visiting other sites for info. Just would like the feedback of someone who has experience this swap already. 2. Where can i purchase either one? I know there are vendors on here, but has anyone had any experience with them, or have found greater deals on other sites? Feedback on that would be appreciated as well. 3 If bought from a vendor, which either one sells a complete swap, what is the major differences between them? Is it just their own pricing because i have seen RB20's from 1000 to 1200. And then theres the RB25 between 1800 to 2400 before shipping on their advertised threads? Is it just plain mark up price? I know for the RB25 sometimes the difference can be whether it is a SI or SII. 4. On the Rb25det, i have read both sides saying the SI is better then the SII, and vice-versa. What is the real difference between the two besides the turbo? Or is it just all personal preference? 5. With the swaps that sell the uncut wiring, that just means i have to do the cutting and wire everything up right? But is this very hard to do? Where can i fine a wiring diagram for either swap? Or better yet, when i get started, can someone in socal help?! Thanks to all who input on the questions asked. Hopefully i can get started on a swap very soon. By the way, i will be swapping it into a 95 s14. |
09-20-2009, 12:09 AM | #2 | |
1. Depends on what you want out of the car. Doing an RB swap is not cheap by any mean's a least set 7k aside to make sure you do everything right( bone stock). Make sure all the maintenance is done water pump, timing belt, tensioners, gaskets, thermo, accessory belts, then what mount set up your going with. 2. On the engine since your in cali make sure you can go and check the motor out, make sure they leakdown and compression check the motor in front of you. If buying a clip they can start it for you also. Just start calling around and see who or what is in stock and then start pricing. Just remember you get what you pay for. 3. The price is going to vary from year to year, later year motors will prolly be more due to mileage. 4. The difference between the S1 and S2 are not very different. If your only looking for 300 rwhp just get a sr or turbo your Ka it will save you money in the long run. 5. when they give you an uncut harness it just means the skyline harness is complete with all plugs and no wires cut. You can to or pay someone to cut plugs and extend wires. I did my swap myself but ive done many swaps before if this is your first or your good with wires and reading diagrams then you should be fine. Not to sound like a dick but if your asking these questions your prolly not ready to do the swap yourself. |
09-20-2009, 12:48 AM | #3 | |
Thanks so much on the info. This really helps out on the swap. First person to actually leave good feedback. Ill reply with kinda questions to your answers though. 1. So then no matter what, even if im not looking to push the motor, right from the start i should replace most parts then? Like all that you mentioned? Im guessing all with aftermarket parts, or try to get oem parts from some sites that i have seen selling them? 2. Well most of the the places i have seen that sell them are either in a diff. country(canada, japan, etc.) or on the other side of the us. I think there are some vendors on here that show the test of which ever motorset you will get but ill have to double check. 3. Ok no need to ask any questions on that. 4. From the prices i have seen, Sr's seem to be more expensive. Plus, even though i can obtain the same power on the SR, the RB sounds more reliable to me the either the SR or KA seeing as it is a 6cy vs a 4cy. Idk maybe i am wrong on this since i may not be looking to gain that much power, but then again.....I might want way more lol 5. So then the wires are already almost basically set right? If thats the case it shouldnt be that much trouble as long as there is a diagram. And i completely understand what you mean. Ill be having my uncle(mechanic) help me with what he can, plus i know it may not mean much to some, but my cousin has just graduated from UTI and has taken some classes on most of the things. He may not know as much as some on here, but he really does know a lot. Of course ill try to look for help here and there. Not trying to make it seem like i know everything when i am just learning myself on this swap and this car. Thank you so much again for the help, really great member!! |
09-21-2009, 10:55 AM | #6 |
09-20-2009, 02:10 AM | #7 |
i didnt even read the thread.... but im gonna answer with RB25!!!!!!!!!
Built RB25 - RB The World - Vertex Everything @RBVertexRidge |
09-20-2009, 02:27 AM | #8 |
rb20 are fine!!!!i have had two. price difference is nuts. you could get an rb20 in your car for like 3k-3500. rb25 is like 5k for the motor itself right???plus the mounts and fmic...
anything rb is pimp shit fo sho!!
09-20-2009, 02:33 AM | #9 | |
Are you including the swap done by someone else? Or are you talking about parts needed to replace? Ok i know i said i had decided that most likely between the two. But i just now started looking at a possible ls1 swap. Is the swap on this easier or harder? Whats the avg. price on this. I am currently looking online(google) for prices but cant seem to find either vendors sellings or recent threads(most are back in 02-06). |
09-20-2009, 02:46 AM | #10 |
hey i have the rb20
and it has never giving me problems people just think that is a crappy motor when is not has all the dam torge you need for drifting and is a really reliable car to get power out of any rb is all about tunning the car the best tune always wins in the end |
09-20-2009, 02:49 AM | #11 | |
09-20-2009, 12:39 PM | #12 |
dude in any swat ur gona wanna replace water pump, thermo, belts,oil pump, tensioners, and anything else necessary...its just to be safe in the long run
-Jorge |
09-20-2009, 12:55 PM | #13 |
09-20-2009, 02:56 AM | #14 |
i personally have an RB25 and the torque is there and i love the fact that i can throw an GT35 at it and be square... i had an RB20 with gt2530 and it was descent... yea,,, i want the RB25 over the RB20. fuck RB20
09-20-2009, 03:00 AM | #15 |
Did you do the swap yourself by any chance? Did you have to change out anything as you were swapping it?
09-20-2009, 05:15 AM | #16 | ||||
LOL @ people with RB20's saying "they're fine". Riding a pedal-bike is 'fine', walking is 'fine', but who the fuck wants to go slow?
If you're going to do all the work of putting a RB-series motor in (instead of a SR, which is drop-in), wouldn't you want something that's actually better than a SR? The price difference between the motors is usually $1000, and you need a new driveshaft (~$300) with the 25 (you can use a stock M/T driveshaft with the 20), but the performance difference is huge - plus, the "cap" on what you can get out of it with a turbo/injectors/maf/tune upgrade is MUCH higher. As far as budget goes, you're looking at $2500 on the motorset, $600 on mounts and a driveshaft, $200 on a radiator, $100 on a timing belt, $300 on new water pump, oil pump, idler and tensioner pulleys, $300 on a intercooler kit, $250 on an intake manifold (stock IM + FMIC = lammmmmme), $200 on wiring (average), and say $200 for random shit like gaskets/fuel filter/fuel hose. That's ~$4700 if you can do it yourself, another $500-$700 to have a reputable person swap it for you. WAY less than $7k. Quote:
PM me for pics of my work/etc and I'll talk pricing on doing the swap with you, or point you to some people that can help you locally.
Jordan Innovations has a new web site! www.JordanInnovations.com -- All your favorite FD Pro Drifters love it, trust me -- www.JordanInnovations.com |
09-20-2009, 10:12 AM | #17 | |
For the parts you mentioned, this is all prices without a state board of equalization license right? So with that said i may be looking at a lil less to spend. Dont think i can use it on a motor set, but on almost all those parts, most likely yeah. Ill shoot you a pm about your work and other questions. Thanks again! |
09-20-2009, 01:23 PM | #18 | |
R.I.P. Aya, always love
Trader Rating: (215)
Feedback Score: 215 reviews
As far as a RB goes stick with the 25 like Jordan said its all about the on tap power stock. I ran a RB25 with a GT2530 and at 11lbs boost I was pushing 300whp on a stock engine with a PowerFC. I did upgrade my injectors and maf though because basically anything over 11lbs boost with my turbo was pushing the AF ratio and the duty cycle on the stock injectors. With that said If you want to go down the RB road I can get you a clip for around $2500 Series 1 or 2 or possibly even a NEO rated 280HP factory at 7LBs!!! They are from a very reliable source and can be compression tested.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
09-21-2009, 05:33 AM | #19 | |
and 250 for intake manifold ? yeah for some janky ass hong kong shit. 300$ for an intercooler kit? I bet everything on your car is from ebay or a knock off . If you are doing any type of rb swap and cant afford to do things right and buy name brand parts and support real companys. I dont know any reputable shop going to swap in a rb for 500-700 bucks lol do you know what labor rate at most good shops are per hour right? IF your going to do the swap make sure you take the time and look everything over and expect to spend more, it always works that way. Do not turn your car into what 80% of the hacked up pos 240's that run on the road. Do it right the first time. |
09-21-2009, 05:55 AM | #20 | |
I have a Godspeed chrome intake mani on my RB25, and the casting (except for the few "rises" I dremeled down on the inside) looks better than the casting on the Greddy IM I installed on a RB25 Formula D car 4 years ago, when I worked for a F-D team. Yes, I've seen them both, up close and personal... no, it's not worth the extra $800. The fucking guy is debating between a RB20 and a RB25, do you really think I should give him prices for a HKS intercooler and a real Greddy intake mani?!? Combined they cost more than the whole motorset. Obviously doesn't apply here. He lives in Socal - I know multiple reputable mechanics that would do a simple swap for $700. Go to a top-end shop like SP Engineering, you're going to pay $100/hr, sure... but again, that's not what he asked for. Pride in your car, doing it right the first time, etc is fine, which is why I don't take statements like yours (about me/my car, which you've never seen lol) personally - but I'm trying to kick down some knowledge about which motor to buy, and what the prices start at so he can have a minimum budget, not scare everyone off with brand name hype.
09-21-2009, 05:56 AM | #21 |
If you go the route using the r33 cross member I will give you stock r33 mounts to help you out, I already have syko performance mounts so you can have my old stock ones if you just pay for shipping.
09-20-2009, 12:01 PM | #22 |
Man w/ CTSV & a Car Seat
Jeez some of you guys in here are stupid. Why do RB20 cost $1k? Cuz nobody in Japan wants them, they are literally throw away engines out here. They are worth just as much as an NA SR20DE out here.
Go RB25, you wont fucking regret it. |
09-20-2009, 01:13 PM | #23 |
check this out looks like a good deal http://zilvia.net/f/sale-items/279408-cheap-new.html
rb25det $2700 installed and running
(OΞO/- -\OΞO) |
09-20-2009, 01:27 PM | #24 | |
09-20-2009, 01:49 PM | #26 | |
Break it down like this RB25DET clip $2500 install kit: around $500-600 Driveshaft made $200 FMIC if you choose to go $350 minimum maybe more Radiator the inexpensive way is to run a S14 radiator $50 Oil cooler is not needed. catch cans are optional fuel pump $90 walbro electric fans $200-300 you should run at least two wiring $375 Greddy Intake $650 new clutch $200 minimum hoses $50-100 electronic boost controller minimum $200 for a decent one. 3 inch downpipe $200 exhaust system $200-350 Right here with the list above its cresting 5k, and this is you putting it in yourself and doing it right. I probably left something out as well as that was just off the top of my head. If you want be cheap than go RB20 but it will not be as nice. If you want someone to do a cheap job that will bite your ass later? Go buy that engine posted for the $2700 install price. Honestly I would not trust an engine that is being sold and installed for $2700, its to damn cheap to be good or done right.
09-20-2009, 02:13 PM | #28 |
Honestly everything depends on your budget for the time being. If you cant afford to do an rb25 swap in one purchase maybe an rb20 would work for you. Not to go against anything Jeff has to say (He definately knows his stuff, and he is doing all my harness conversions) but for some people a 5-7k swap is a little much. But 3k here then another 1k this month and another a few months later kinda works out better for them (or those who simply cant save large amounts of cash)
You can do a good running 230whp rb20det for well under 4k running. A few months later you can do a mild t3t4 turbo upgrade with fuel and run a MAP-ECU to get rid of the maf and calibrate for much larger injectors for less than another 1500.00(easily capable of 350-400whp). Ive built more than a few shares of swaps by this time. So I can attest to taking your time and finding ways to save a little bit of money goes a long way. Heres a simple breakdown list with numbers also since everyone else here is doing it: Rb20det swap - shipped all day for 1300.00 complete (Easily found for under that) All gaskets and timing stuff - $300.00 Waterpump(n1) - $200.00 Harness - $250.00 or less Clutch - $400.00 Downpipe - $170.00 Push fans - $100.00 Mount Kit - $300.00 Flywheel Resurface - $30.00 Fluids - $50.00 FMIC kit - $500.00 (hi-ballin that cost via ebay) Total - $3600.00 installed (if you do it your self) An RB25 with about 30-60whp more will run you another 1500.00 or more dollars on top of that. Sure the potential is there but for your power goals of under 400whp I wouldnt waste the dough. For another 1500.00 and searching forced induction classifieds like honda-tech you can get turbos, tial wastegates and injectors for dirt cheap these days. And you would make a guaranteed 350-400whp or more if you feel like pushing an rb20 way over its limits. Anything over 400whp I would do a 1jz or 2jz swap. Costs about the same as an rb25 swap but with 10x the potential. |
09-21-2009, 11:16 AM | #29 | |
Edit: I see you've made up your mind to do the 25. Go for it. |
09-21-2009, 11:24 AM | #30 |
Because buying a RB20 would be like buying a SR20 thats older, harder to find parts for, heavier, bigger, more expensive, and just an overall mess. RB25 if you wanna go RB, unless you got a RB20 for free.
