Old 05-05-2003, 08:36 AM   #1
nnkfws333
nnkfws333 is an unknown quantity at this point
Send a message via AIM to nnkfws333
Evaporator removal
How do you remove the evaporator inside the cabin? Ive removed all the R12 and was it just take off the dash and stuff or what? Trying to find the easiest way to do it on an S13. Thanks for the help.
nnkfws333 is offline   Reply With Quote
Old 05-05-2003, 10:33 AM   #2
the head
the head's Avatar
I removed the entire ventlation system and replaced it with a super compact heater system
you need to remove the dash to get all that stuff out
Old 05-05-2003, 12:02 PM   #3
nnkfws333
so you take out the entire dashboard (including glove box) and is it just a few bolts that hold the evaporator in?
Old 05-05-2003, 09:02 PM   #4
the head
the head's Avatar
evap is inside plenum when you remove it you will need to make a plate to cover the hole in the heater plenum if you keep the stock unit
yes the whole dash it is behind about 60% of it
Old 05-05-2003, 09:17 PM   #5
nnkfws333
thanks for helping me out. I appreciate it but can I ask another quick question? well I was planning to get another evaporator from a junkyard or something so would I still need to make a plate? Why would I need to make one. I didnt quite understand.
Old 05-05-2003, 10:44 PM   #6
the head
the head's Avatar
If you remove the evaporator and are not putting another back in there is a hole in the heater plenum if you are not going to install another evaporator than in needs a plate
