![]() Join Date: Jan 2007
![]() Feedback Score: 8 reviews
What the HELL is this?
![]() It does not have anything attached to it my guess is that it is a weight or something? it attaches to the fire wall and thats it. Does anyone know if it serves any purpose at all? |
![]() Join Date: Nov 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
I am quoting myself because I already said what this piece is and what it does. S13's and S14's have them, S14's also have a dampener like this on the stock exhaust piping next to the diff. They are not needed, it was just something Nissan did to quiet the car down or reduce vibrations.
![]() Join Date: Dec 2002
Firewall, right behind the head. As stated, it's a damper. Remove it.
Precisely where it is, Anyways ok that makes sense that it is a noise dampener, Awesome! at least its something haha. I thought it may have been a weight or some sort of grounding box for some reason. Another question of what something is... What is that Green small square box thats mounted to the drivers side fender?!?!
#14 | |
S13 SR|G37|E46 Wagon|X5 35d Last edited by S13SILVIA|E46M3; 09-30-2009 at 11:03 PM.. |
#22 |
![]() Join Date: Dec 2003
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
I've always wondered what that was... I took mine off a while ago... The S14 one is much sleeker looking than your junk s13's hahahahahaha!
Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
#23 |
![]() Join Date: Jun 2007
Trader Rating: (22)
Many of you are asking where it's located. So here is a pick, this thing saved me after I flew off a cliff, NISSAN Robotic search dogs came and found me.
#25 |
![]() Join Date: Dec 2006
soooo....why are we all gun-ho about removing any piece of vibration dampening off a unibody car that is spot welded and glued together?
What does it weigh...2 lbs? Just put down the cheeseburger instead. to be useful. If you have any questions about what a plug does on the s13, just drop me a PM. I have some nice hard to find wiring books that were dealer only and out of print. They contain diagrams, descriptions, and pin-outs of all the chassis/engine wiring.
#26 | |
Username Monster!
DUDE..LMAO.. I Laughed my Ass Off.. ![]() ![]() ![]() ![]() |
#28 |
Can't this thread died already?
Especially when this topic is as old as Elton John. The first person to ever pull an engine from an Schassis discussed this.
#29 |
guys, i have an S13 and i have the same noise dampening box on my firewall.
i think mine is broken. it must have stopped working because i have alot of noise and vibration in my car. can someone tell me how to fix my noise dampening block? |
#30 | |
Trader Rating: (22)
There are 2 pins inside, you must get the OEM NISSAN Part #J4440-F53-TPA3. Use this tool to open the box and you will see 2 round connectors with gray protective caps that require a 2.5mm socket to remove. Under the protective caps you will find the connectors colored red for positive charged electrons and Black for negative charged electrons. Next you will need NISSAN Part#J4440-F53-TP5, this tool will allow you to charge the unit with special type of electrons, you will have to charge this exactly for 2 hours 25 minutes and 44 seconds to assure proper capacity of electrons have traveled into the device, once that is complete you can press the little red button and the device will self close and beep 2 times with a long tone to alert you that it's on and it will self close in 5 seconds , fallowed by a short single beeptell to tell you it's back online and operating. Do this with caution, these devices have tremendous amount of force when they close, somewhere around 500 pounds of pressure, so it could hurt you. If you need somebody to fix it for you I charge $155 for the repair |
