Old 11-16-2009, 08:45 PM   #1
03silverblaze
03silverblaze is an unknown quantity at this point
S13 not starting well. Help please!
Hello, I was hoping someone could help me. My bf recently purchased a 92 240 coupe with the KA24de motor (automatic). It has about 150K miles on it. Recently, it has been having issues starting up. It'll crank but the car just won't start. It's not a battery or alternator problem. After a few
(or many) trials of stepping on the accelerator all the way and turning the ignition, it fires up but he has to rev the car a bit and keep it at around 2Krpm until he lets it go and the car idles on its own. If he doesn't do this, the car will just die again immediately after starting up.
What could the problem be? Please help
03silverblaze is offline   Reply With Quote
Old 11-16-2009, 08:49 PM   #2
M11's
M11's's Avatar
M11's is an unknown quantity at this point
vacuum, timing, dissy cap/rotor, plugs and plug wires. could also check grounds in engine bay.
M11's is offline   Reply With Quote
Old 11-16-2009, 09:11 PM   #3
03silverblaze
Thank you. We'll take a look at those things.
Old 11-17-2009, 01:03 PM   #4
Big_Balls_JC_S13
Big_Balls_JC_S13's Avatar
Big_Balls_JC_S13 is an unknown quantity at this point
Send a message via AIM to Big_Balls_JC_S13 Send a message via MSN to Big_Balls_JC_S13 Send a message via Yahoo to Big_Balls_JC_S13
I would find out what was just recently changed or something along those lines also check your starter, ingnition switch and such. IDK if it is different but in my s13 the ignition switch was just a little loose where the key tumbler connects to the ignition switch and it posed to be falling in and out of connection causing the starter on my car to get all messed up...Well look in to that and tell me what happens.... PM me...LATE
Big_Balls_JC_S13 is offline   Reply With Quote
Old 11-17-2009, 01:06 PM   #5
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
start with plugs. my car recently did the same after i cleaned the aicv with carb cleaner and it fouled the plugs. sounds like your prob. just change them .
s13drob is offline   Reply With Quote
Old 11-28-2009, 03:58 AM   #6
03silverblaze
Thanks for the help guys. Turns out, we had to replace the fuel filter AGAIN. We had just installed a new one less than a month ago and it's already clogged. I'm thinking there's some junk or built up debris in the fuel tank cause it should not have been clogged so quickly. Especially when we put good fuel in there, like Shell. Anyway, after that, we replaced the already worn as hell fuel lines and stopped a few of the oil leaks. Car's starting up great now and has no issues shutting off when gearing into reverse. We just have to set aside some time to clean out that dumb fuel tank as well as gain the opportunity to work on the tranny as well. We might have to get another one because it takes to long for the car to shift from 1st gear to second. It revs up to almost 5K rpm before shifting and when it does, it shifts hard. Once again, thanks you guys. I'll keep you posted.
Old 11-28-2009, 11:59 PM   #7
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
Let me be first to thank you for your first few posts here on zilvia being legit and informative. welcome!
Tantwoforty is offline   Reply With Quote
