10" wheel- what size offset on s14
any pic's. i dont want to flare the fenders or widebody... just want to tuck 10" width rims with just rolling the fenders. i'm running a concave wheel.
Man w/ CTSV & a Car Seat
Search thru the wheel fitment thread. Its not hard to tuck 10" wide rims on an S14. Also, offset is not the only thing you have to consider, you'd have to think about how wide of tires you want to run. Skinnier, stretched tires means lower offset. Higher offset will afford you wider tires. Then you still have to consider your camber. More camber will tuck more tires under the fender.
![]() Join Date: Mar 2008
i have a 18x9 +25 out back and it's pretty flush at stock camber specs (1 degree) but i have like 2 inches on the inside before i start hitting the coilover...so if you want max rubber at zero/low camber i'd say a 18x10 +30 or +35?
