Car wont start!!!!!!
its sparkin...
i put a little fuel in the intake manifold..it popped...then no more. im thinkin its not gettin fuel..how would i check if its gettin fuel without takin an injector off or somethin... thats the only possible think i can think of as of now that could be the problem.. any others i over looked???
lemme have a dollar |
![]() Join Date: Dec 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Are you sure it doesn't start and then die?
I'm assuming you have gas in your tank. What did you change to make your car not start? Can you hear your fuel pump running? Check undercar for broken lines yet?
well i did a rebuild..so no tellin an di got gas..old gas
im pretty sure it doesnt start and then die i think i hear my fuel pump....that wherr from the rear..its not loud like my antenna motor if my lines were broken...wouldnt they leak???
![]() Join Date: May 2002
pull out your spark plugs and crank. do you smell gas or see it shooting out of your pistons??
also, remove your cas, while noting the position of its timing, with your car on the on position(remember to disconnect the ignition coil, turn the rotor. do your injectors fire?
- -- - '93 240sx coupe '93 taurus wagon -kalieaire (maybe grinder too on special occasions) |
well now i know its gettin fuel...too much fuel..its kinda flooded
is it possible for the injectors to inject too much fuel??(like be open too much) now wut???
if you searched, you'd have found posts like this.
#11 | |
really, i'm not kidding that your idle can be affected by these other problems. and several others that i haven't bothered to add in since there're too many to list.
well..would it make a difference if i have almost no back pressure
ie no exhaust or cat..jus B-pipe/down pipe. i mean all the plugs are firing(took them out and looked) i dont mean the cylinders are firing... my alternator was fine before i rebuilt the motor Scene: ok...while trying to start the motor we eventually got it to fire a few times after moving the distributor but only a few times because the fuel lines weren't connected (because i had too much fuel in cylinders) then we hooked up the fuel lines... put the battery charger on and turned the motor over and move the distributor around but nothing happened..no popping or any thing. can anything be gathered from this???
![]() Join Date: Jan 2003
unless you a have a T25+ powered SR you dont have to worry about that back pressure issure with NA motors. but i dunt know man, sounds like sumtin with the alternator to me, same problem i ran into when i bought my first 90 240sx which i am now parting out
#14 |
if the ignition timing set on your cas is incorrect, your engine won't start either.
