4 to 5 lug adapters
Anybody ever seen or used these and are they worth it, pros/cons?
http://www.speedalliance.com/images_...b_adapters.jpg Thanks, Keith |
It is basically a (fairly wide) spacer. You will need to take it into account in the offset of whatever wheels you are going to put on them. Given how simple they are, the only drawback I see is additional rotating mass, any other comments?
Rowsdower saves us and saves all the world! |
I don't see how they connect to the stock 4 lugs/hub. lugs are splined going through the hub, so you can't screw them into the back like that... what am I missing?
edit: Wait a second, so you have to unbolt/bolt the thing together yourself? So first you torque down the 4-lug side to the hub, then you bolt the 5-lug side onto the 4-lug side, then mount the wheel and torque it down? ... wow. Long process... if I'm right that is. I guess it's hard to do any other way, but... still.
Instagram: @SX180HKG Last edited by adey; 05-26-2003 at 10:30 PM.. |
This is speculation because it's been a while since I last took off my rotors, but it looks like there are two peices to this thing. The front goes over the lugs, the back is attached to the other side of the hub using those hex bolts? Maybe? Possibly?
#6 | |
![]() Join Date: May 2002
i wouldnt use those. but that's just me. i dont feel safe w/ a converter. im sure it is but...i recall someone's breaking due to either not checking or poor quality
just get the real 5 lug conversion and be done. if you only have 2 wheels you like go w/ the dope 20 lug (4 lug front 5 lug rear or vise versa) conversion ![]() |
I think they are around $180.00. I like the idea of the added offset and the abundance of 5 lug wheel choices. I can't quite make out how they attach to the existing 4 lug given the thickness. Even if it is 2 pieces the inner section would need to carry the 4 lug thread and a counter sunk lug nut before outer portion is attached. What am I missing?
Thanks, Keith |
#10 | ||
![]() Join Date: Mar 2002
![]() Feedback Score: 9 reviews
I just found out that those converters space the wheels out by 45mm. If I were to get these converters, i would put on the s14 stock SE rims. If I used these converters, would even the stock rims stick out from the fender? Or would they be flush?
s13 92 White 240sx SE Coupe ![]() |
#12 | |
stock is +40 you'd make the offset -5 yikes! |
