Old 01-21-2010, 07:03 AM   #1
11Past9
11Past9 is an unknown quantity at this point
SR20 timing belt... Interference?
Is the SR20 black top engines timing belt an interference timing belt? The JDM motor is said to have 40k on it. Only 700 mi since the swap, belt was inspected for cracks, rot etc and looked good. Should I be concerned? What happens if the belt breaks?
11Past9 is offline   Reply With Quote
Old 01-21-2010, 07:19 AM   #2
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
there is no timing belt, it's a timing chain.
and whoever told you 40k is lying. everyone says 40k miles.
clark is offline   Reply With Quote
Old 01-21-2010, 07:24 AM   #3
11Past9
Timing chain on an sr20det blacktop? So nothing needs to be changed or worried about?
Why no faith in the 40k?
Old 01-21-2010, 07:30 AM   #4
attracted
attracted's Avatar
attracted is making a name for him/her selfattracted is making a name for him/her self
chain can stretch/crack/break
also tensioner can go bad...
attracted is offline   Reply With Quote
Old 01-21-2010, 07:34 AM   #5
11Past9
Can, but is it common? Should I worry about it or change it?
What happens if it does? Anything catastrophic or just, bla crap I gotta change it out?
Old 01-21-2010, 07:43 AM   #6
OLDSCHOOLRICE
OLDSCHOOLRICE's Avatar
OLDSCHOOLRICE is an unknown quantity at this point
Like Clark said "everybody says their sr only has 40k on it". It's pretty unlikely that they all only have 40k.
I also wouldn't put too much faith into someone who told you they inspected the "timing belt" on an sr and it didn't have any cracks.
SR is an interference engine, so yes it could be catastrophic if the chain broke. If you're planning on beating on the engine I would replace the chain, tensioner and guides.
OLDSCHOOLRICE is offline   Reply With Quote
Old 01-21-2010, 08:59 AM   #7
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
only way to no for sure is if you got a clip...and even then...someone could have swapped clusters.but its unlikely...and as far the timing chain goes, i'm pretty sure its 90k miles and it needs to be replaced. i've replaced my chain tensioner twice though i think
sidewaysil80 is offline   Reply With Quote
Old 01-21-2010, 09:02 AM   #8
11Past9
No it has been 700 since the swap. I've got all reciepts for the engine and trans etc. I just want to know if I should worry about the chain or not. How much would it cost to do just to be safe or is it really not that big of a concern?
Old 01-21-2010, 09:31 AM   #9
Sterlz
Sterlz's Avatar
Sterlz is an unknown quantity at this point
Like oldschoolrice stated if you plan on beating on your SR then you should definitely change guides chain n tensioner.
Sterlz is offline   Reply With Quote
Old 01-21-2010, 10:08 AM   #10
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
there are a few things that are a good idea to do when getting a clip
water pump, front main and rear main seal, oil pick up...
timing chain is also one
depends how cautious you want to be and how deep your pockets are
Old 01-21-2010, 10:15 AM   #11
11Past9
The car has 700 miles on it since the build. It seems that everything was addressed. If I were to call the guys who sold the engine would they know or should they be trusted? There must be some reputable places that don't just sell sr's that are shit. The current owner who is a friend of a friend said the compression was tested and everything was inspected before it was dropped in. I can't imagine someone would put this much money and time into a build and ignore the essentials.
If I wanted to do the timing chain, how much would it set me back?
Beat on it? As in daily drive it, some hard pulls and playing around? Or do you mean drifting, melting the tires, hard launches and total disrespect of the car?
Old 01-21-2010, 10:53 AM   #12
clark
clark's Avatar
honestly, you're asking alot of questions that are answered in the engine FAQ.
an SR engine really is no different than any other engine. it needs maintenence done at specific intervals.
since it's new to you, you need to perform a pretty thorough inspection of alot of stuff inside and outside of the engine.
Old 01-22-2010, 10:15 AM   #13
tkocrewsr
tkocrewsr is an unknown quantity at this point
Ok here it goes,First who or where is the reputable shop that did the swap and your willing to take someones word that they checked everything even when you say timing belt.it all depends on how your motor was previously taken care of which you don't know the motor was probably sitting in a crate somewhere for six months or so.It also sounds like you don't even own the car if your going to buy it double check everything before you buy it to cover your own a$$.The sr20 market is just like everything else in the world another field to possibly scam or screw you,so if you dont take the time to check it out properly and come back here two weeks after you bought saying that its making loud noises i am going to laugh at you.It is best to do the best possible preventative maintenance on the car if your going to daily the thing.I got bought my motor from a reputable place and it was very clean and i beat the snot out of it all the time,but dont take my word for your motor.
If your going to buy this thing do a little research because it doesnt have a timing belt and be sure to double check it!
tkocrewsr is offline   Reply With Quote
Old 01-22-2010, 11:11 AM   #14
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
Dude its not that people sell shitty SR's, which some do, but the condition of the engine is literately based on the maintenance done when it was in the Silvia. It's likely that its fine but you'll never know unless you inspect it. Also his credit went out the window when he said it was a belt; that's just a straight lie...
GL with it, become friends with the search feature
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 01-22-2010, 03:11 PM   #15
11Past9
He corrected himself, I said belt. He said that him and Josh (my friend) took the valve cover off and inspected the chain and everything before they put it in. The compression was tested as well. It's not a million dollar job car but I can tell he took the time to put it together right. He didn't use cheap parts either and he knows his cars pretty well. He's also got a 94 TT Supra BPU, a 20G 07 STi and this was his third car. Josh has built many SR's and currently has two of them. I trust them. I see nothing that indicates a hackjob.
Old 01-22-2010, 03:15 PM   #16
11Past9
The motor was bought through japan star motor fyi
Old 01-22-2010, 08:23 PM   #17
tkocrewsr
about japan star motors i cant comment because i dont know anything about them,but the morality is just check things out before you buy so you dont get screwed.
Old 01-22-2010, 08:38 PM   #18
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Fuck all that noise about the chain. I'd be worried about the oil pump before anything else. If you plan on cracking the engine open, I'd replace that with a new one. The chain question comes up because if you're pulling the oil pump off, might as well change the chain and chain guides while you're at it since they're pretty much accessible with the pump cover off.
CLICK HERE!!!
Old 01-22-2010, 09:54 PM   #19
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
where did you read this? someone here possibly including yourself is very dumb indeed
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 01-22-2010, 10:50 PM   #20
11Past9
Anyways back to productive responses
