Old 01-24-2010, 08:53 AM   #1
Kaifd3s
Kaifd3s's Avatar
Kaifd3s is on the path to ruinKaifd3s is on the path to ruin
Coilover Strut loose?
Last night I finally installed my PBM coils. I went to take the car for a spin, and I hear this really loud metal on metal tapping noise. I had my friend continue to drive the car (only about 35mph max) as I sat in the back to see what was happening.
On the passenger side rear coilover, it seems that everything is tight. The strut is moving up and down with play. Its like while he was driving the car, I literally felt the the middle piece of the top mount (not the top mount, the actual piece connected to the strut) moving up and down each time the noise was made.
Any idea's how to fix it?
Kaifd3s is offline   Reply With Quote
Old 01-25-2010, 12:44 PM   #2
Kaifd3s
Kaifd3s's Avatar
***Update***
After spending literally the whole of last night on google and this forum, I finally read something about the top nut getting loose on the stance's.
I woke up this morning tightened it down and im good as new....
Old 02-05-2010, 04:47 PM   #3
VG30Drift
VG30Drift's Avatar
VG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymoreVG30Drift is not welcome here anymore
excellent. I'm having a similar problem, and since it pertains to your question I will ask it here. When you're tightening said pillow ball mount nut, you use spanners to hold the top of the strut in place so it does not simply rotate the whole thing when tightening. However, my driver's side strut simply rotates when trying to tighten even though my spanner is holding the top most adjusting bracket in place. The whole half of the strut is rotating independent of the "top spanner adjustment bracket collar thing." Is this normal or are my Stances borked?
'94 NA Z----------------'90 S13 Base Coupe
VG30Drift is offline   Reply With Quote
