Old 03-11-2010, 09:07 AM   #1
tossaxe
tossaxe's Avatar
tossaxe is an unknown quantity at this point
Question Rear Strut Bar install
Hello,
I can't find access to the rear suspension mount to install the rear strut bar. How do you remove the package shelf??
tossaxe is offline   Reply With Quote
Old 03-11-2010, 09:09 AM   #2
murda-c
murda-c's Avatar
Originally Posted by tossaxe View Post
Hello,
What kind of car do you have? if it's an s14 with the round speaker covers, just pop it up. if it has the larger speaker covers you need to unbolt the rear speakers first.
Old 03-11-2010, 09:13 AM   #3
tossaxe
tossaxe's Avatar
Yes, its an s14 '96. well the loudspeaker grills have no visible screws from either side. And ir requires quite a lot of strength to pop it up, if it is how it should be done, I kind'a afraid to brake it.. But if it's how it should be done, i''ll try.
Old 03-11-2010, 03:57 PM   #4
projectRDM
projectRDM's Avatar
This is incorrect. All S14 model rear deck covers simply snap up, there is no way to remove the speakers or their grilles until the cover is out of the car.
FORMERLY R240NA
Old 03-11-2010, 09:16 AM   #5
enkei2k
Super Moderator
Trader Rating: (29)
enkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfection
Feedback Score: 29 reviews
just pop it off and remove the rubber dust boot cover things. does your bar go over or under just curious?
Ask enkei2k
xquizitditz
enkei2k is offline   Reply With Quote
Old 03-11-2010, 09:20 AM   #6
tossaxe
tossaxe's Avatar
Thank You All
It goes under =]
Old 03-11-2010, 09:38 AM   #7
tossaxe
tossaxe's Avatar
Thumbs up
Well it work so I am happy
Although it seems I've misunderstood the direction of popping it off. It's much easier and safer to the trim if you:
1) remove the black near vertical trim just behind the seats
2) and slide the package self towards the front of the car
Old 03-11-2010, 09:43 AM   #8
murda-c
murda-c's Avatar
Weird, for my car i just flip down the seats and lift up on the parcel shelf.
good you got it done though
