Old 03-21-2010, 12:39 PM   #1
dued
dued's Avatar
dued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymore
Thumbs down Clutch stuck to floor, towing questions?
Hi, my clutch is broken, I have no pressure from the pedal. My car is stuck in first gear & I can't shift out. I would like to know if a tow-truck driver could potentially damage my tranny / clutch by dragging the car onto his truck bed. Also, would I damage my transmission if I ripped the shifter out of first gear even though it's stuck? Thanks for the help.
dued is offline   Reply With Quote
Old 03-21-2010, 01:16 PM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
your clutch slave is out possibly. the tow truck will damage your tranny. you can try to pull out of gear. i wouldnt know if it would cause it to be damage.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 03-21-2010, 01:36 PM   #3
Sileighty_85
Sileighty_85's Avatar
try and rock the car back and forth while pulling the shifter into neutral, make sure the ebrake is off too, It might be on and putting a load on the tranny making it hard to get out.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 03-21-2010, 01:56 PM   #4
I LUV MY S13
I LUV MY S13's Avatar
hahaha...
its just a clutch fluid leak, most likely the slave...check it out, fix it, the end
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 03-21-2010, 02:05 PM   #5
PNgo12
PNgo12 is an unknown quantity at this point
this happened to my friends integra, we just bled it and it was fine again, but about your tow truck damage thing i dont know if it will damage it
PNgo12 is offline   Reply With Quote
Old 03-21-2010, 02:09 PM   #6
SilviaAura
SilviaAura's Avatar
SilviaAura is an unknown quantity at this point
tow truck would probably damage your car...i had the same problem on my car...i replased my clutch master cylinder and i bled it out and it works perfect now...it will only colst you about 50 bucks tops if you do it yourself and its pretty easy...autozone pats though...
SilviaAura is offline   Reply With Quote
Old 03-21-2010, 02:12 PM   #7
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
does the clutch pedal not return? it cuold be that the pedal's fork or whatever is broken, you might want to actually look at the clutch itself, it probably isn't cause that would not explain why the clutch won't come out of gear.
Old 03-21-2010, 02:13 PM   #8
LB 180SX
LB 180SX's Avatar
Trader Rating: (18)
LB 180SX is an unknown quantity at this point
Feedback Score: 18 reviews
ur slave is damaged. rock the car back n forth and have sum 1 pop it out of gear. yes the tow truck will f*** it up. just bleed and it will be back to normal. good luck
LB 180SX is offline   Reply With Quote
Old 03-21-2010, 02:15 PM   #9
I LUV MY S13
it wont fuck up if its on a dolley...
-Jorge
Old 03-21-2010, 03:00 PM   #10
Marc240
Marc240's Avatar
Marc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-knownMarc240 is making his/her stupidity well-known
^dollys arent exactly low car friendly...
http://i48.photobucket.com/albums/f209/mj2545/logo.gif.com
Marc240 is offline   Reply With Quote
Old 03-21-2010, 04:41 PM   #11
dued
dued's Avatar
Thanks for the help, I was able to get the car in neutral + have it towed to a shop nearby. It seems as though the clutch fork went out and my slave cylinder fluid is also really low.
Old 03-21-2010, 06:13 PM   #12
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
^is that what they told you? I have never actually seen a fork break. The fork pivot is more prone to breaking I think.
Now would be a good time to get a SS clutch line and bypass the stock dampner if you havent already... SPL sells them for like $20
az_240 is offline   Reply With Quote
Old 03-22-2010, 09:31 AM   #13
SilviaAura
SilviaAura's Avatar
i bypassed the camper by simply bending my stock line =] it works great!
