Old 04-06-2010, 11:28 PM   #1
jesse the e-thug
jesse the e-thug's Avatar
jesse the e-thug is an unknown quantity at this point
Z32 to S13 E-brake cable adapters
I NEED Z32 to S13 E-brake cable adapters long story short i did a z32 swap brake conversion include calipers rotors and e brake assembly and it didnt work so i was told that i need a e brake adapters/extensions i seriously don't know where to get them or if i actually need them, please help me out need my car to be running i broke some rotors the first time don't want that to happen again i was going through a 5 lug conversion forum and ran into some problems when i read his thread http://forums.nicoclub.com/zerothread?id=277821 it says that i have the wrong anchor bolt but does anyone know the reason why its the wrong one... LMK ASAP LOCATED IN LOS ANGELES PLEASE HELP!!! i believe this is how they look like if you have any more info on this lmk ASAP i might be wrong...
anchor piture :
extension picture :
jesse the e-thug is offline   Reply With Quote
Old 04-07-2010, 10:19 AM   #2
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Don't need extensions on an S13 swap
re-route the lines and some rubber holding grommets
is all I needed on mine years ago
in that first picture, looks like parts from the shoe assembly
and this info is so old, I think Moses (aka Russ) wrote it down on a stone tablet before the internet
Old 04-07-2010, 01:38 PM   #3
jesse the e-thug
but does the anchor does it really matter which one i have tt or not tt one?? because they keep telling me that i can't use the tt z32 anchor that i need the none turbo one dont know why or what does it matter if you guys know can you please let me know asap ... really need the help
Old 04-07-2010, 02:23 PM   #4
94_240sx
94_240sx is on a distinguished road
I'm the one who found this info back in the day and that's my picture.
It's because the hub. There's a spacer on top of z32 hub for the anchor bolt on the left side. If you use the one on the left side(thinner one), there's some play and people believe that it's not safe.
As far as cables go, get the adaptors. I used them and work pretty good.
courtesyparts.com
94_240sx is offline   Reply With Quote
Old 04-07-2010, 02:30 PM   #5
jesse the e-thug
where can i find the anchor that's on the right? if i use the one on the left is there a high possibility of failure? i figured out the ebrake problem already thanks though.
Old 04-07-2010, 09:07 PM   #6
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
Z32 90 N/A Ebrake Anchor bolt
i think this is what you're looking for right?
upsdude is offline   Reply With Quote
Old 04-17-2010, 12:02 AM   #7
slim_240
slim_240 is an unknown quantity at this point
i have the similar problem. i needed the fatter anchor bolt since my z32 rear hubs don't have the extra tab on top. i don't know why you'd need cable extensions unless you ran the stock s13 cables.
slim_240 is offline   Reply With Quote
Old 04-17-2010, 01:11 AM   #8
89_240jdm
89_240jdm's Avatar
Trader Rating: (183)
89_240jdm is on the path to ruin89_240jdm is on the path to ruin89_240jdm is on the path to ruin
Feedback Score: 183 reviews
Talking
89-90 z32 n/a hey look like s14 hubs hey dont have the top tap that is use to hold on to the anchor bolt on the z32 e-brake assembly... you can use spacer on the anchor bolt..to run with the smaller z32 anchor bolt or fine a 89-90 z32 anchor bolt.or some washers. ..
z32 91-96 n/a hubs with tap..
z32 89-90 n/a hubs look same as s14.. with out tap
89_240jdm is offline   Reply With Quote
Old 04-17-2010, 09:51 AM   #9
Koukimonsta18
Koukimonsta18 is an unknown quantity at this point
Im confused. I have kouki five lug hubs.
Im about to buy:
z32 30mm aluminum calipers
R33 e brake cables
Stainless steel braided lines.
Anything else I need?????
Koukimonsta18 is offline   Reply With Quote
Old 04-17-2010, 05:20 PM   #10
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
Im about to buy:
R33 e brake cables
if you are going to do the rear z32 calipers (I assume so since u purchased the correct e-brake cable) you will need the rear backing plate with ebrake assembly from a z32/gtst along with the caliper and rotors.
You may want to visit importnut and see what all is needed in the conversion.
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 10-23-2011, 07:52 AM   #11
stance
stance is an unknown quantity at this point
So it's okay to use washer/spacers? Would I still need to fasten a small bolt on the anchor to the backing plate?
stance is offline   Reply With Quote
Old 04-17-2010, 05:18 PM   #12
rican_nick
rican_nick's Avatar
2 washers the same size as the washers on the axles work fine as anchor bolt spacers.
Nick O.
97 240sx
Old 10-23-2011, 08:41 AM   #13
ZX88
ZX88's Avatar
ive recieved two different sized anchor bolts i just used two pacers on the smaller on to space it out to the size of the larger one. its been fine for over a yr now.
Old 10-23-2011, 08:55 AM   #14
stance
Did you also bolt the anchor to the backing plate? Noticed the thinner anchor doesn't have threading
