![]() Join Date: Jul 2002
Key Is Stuck After Auto to 5spd Swap
well the title pretty much says it all, anyone know how to get the key out of the igintion? And yes I try to press the black button but nothing.
![]() Join Date: Nov 2001
Unscrew the stupid electronic lock from your ignition. There is a safety mechanism that attaches to the ignition, there is a sensor on the shifter. Basically, it doesnt allow you to remove the key UNLESS the car is in park.
Come on man, you're converting from auto to 5-speed and cant figure that out? Sheesh... ![]() |
![]() Join Date: May 2003
And we need to know S13 or S14...
S13 = Electrical S14 = Mechanical - If S14, remove the plastic trim and you'll see the cable...unclip/remove it, and Voila! If S13, see what old_S13 said above. Later - Brian |
#6 | |
![]() Can someone tell me what this looks like and exactly where it's located? Thanks! |
![]() Join Date: Jul 2003
pop open that little thing, pull the lil red switch and take out your key,,,,, as for the permanent solution im trhinking hook up that key thing to neatral position switch,, or wait...im wrong
dont u hate that flexing the conv gives!
-Kevin Z31T s13 hicas |
I hate you too...
![]() Join Date: Jul 2001
Its right behind the key on the S14. Its a cable tube (flexible, 1/8" or so) that feeds into a black plastic box that is directly behind the key. It should be held in by a couple screws. Simply unscrew it, and the mechanical wedge-shaped key-lock will never bother you again.
-Jeff
Whatup? |
![]() ![]() Feedback Score: 3 reviews
If S13 remove teh trim around the steering column it is the black and white box attached to the ign cylender(sp) it is held on by two screws remove them and take the thing out then reassemble the trim on the column
I never knew you could do that with an eggplant |
#10 | |
Bonus question: What is the orange box that was bolted in there the clutch pedal goes? |
#12 | |
#14 | |
Re: ...
