Old 05-20-2010, 08:24 PM   #1
90s13coupe
90s13coupe is an unknown quantity at this point
first ever swap
Alright sr guys this is my first ever swap and im having a hell of a time getting it running, its just stock sr into s13, i got a brand new engine harness and spliced all the ka plugs onto the sr harness just like it shows on frsport, the base timing and ignition timing are on its getting spark and fuel but it wont fire. Also the only way it will crank is buy using a jumper wire from the battery to the starter, it wont cranck with the key. I dont know what else to do seeing that im new to this whole sr swap stuff any tips would be awesome. Thanks guys
90s13coupe is offline   Reply With Quote
Old 05-20-2010, 10:12 PM   #2
Ceepo
Ceepo's Avatar
Are your fuel lines backwards, when you set the timing are you sure you were at tdc, and did you do the wiring right, and was it a auto to manual swap?
Old 05-20-2010, 10:19 PM   #3
S14DB
AFC #1
S14DB's Avatar
Auto to manual?
Old 05-20-2010, 11:28 PM   #4
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
+1, i had my fuel lines backwards at first, fixed it then it fired right up
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 05-21-2010, 09:18 AM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Did you wire up the wires by the ECU into the dash? I'd start by double checking those first.
CLICK HERE!!!
Old 05-21-2010, 11:17 AM   #6
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
This shouldn't affect starting the car though. When I swapped my SR into my old S13, I left the plug unplugged (still needed to splice it) but I knew that was just for the interior stuff, wanted to make sure it started so I cranked it and it started perfect, but it will not turn off if that white plug isn't plugged in/spliced right. Thats when you go to the engine bay and rip out the fuel fump fuse or something.
Sounds to me like some wiring issues. Only way to crank it is to jump the starter, something is wrong there...
DataXUnknown is offline   Reply With Quote
Old 05-21-2010, 11:31 AM   #7
driftn_silvia
driftn_silvia's Avatar
driftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to all
It could be the ECU its self, my buddy and I had problem tryin to crank. We were working with a S13 Blktop Sr. Then switch ECU to a J4 and it started right up.
So try to get one of your buddys ecu and check that, other than that try check the wiring.
driftn_silvia is offline   Reply With Quote
Old 05-21-2010, 05:00 PM   #8
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
I had this same problem and it was the starter relay and make sure all of your lower harness is installed correctly
jacobs13 is offline   Reply With Quote
Old 05-30-2010, 10:03 PM   #9
90s13coupe
thanks for the help guys i figured it out, ecu wasnt screwed in completly, stupid mistake, and the reason it wouldnt start with the key is because the bracket on the clutch petal doesnt have the little rubber or plastic cover on it where it pushes the clutch safety switch button, runs great now, thanks again for the help though
Old 05-30-2010, 11:56 PM   #10
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
haha glad you found the problem! small problems created big drama
Slammed Assassin is offline   Reply With Quote
Old 05-31-2010, 12:23 AM   #11
Sterlz
Sterlz's Avatar
Sterlz is an unknown quantity at this point
clutch safety switches are always a PITA
Sterlz is offline   Reply With Quote
