![]() Join Date: Aug 2001
Allright.. whats the deal...
i installed a kicker 4 channel amp, ran 8 guage wiring to it.. etc.. etc.. it's running all my speakers inside my car.. now my speakers whine with my engine! HELP!!> |
WOW addicted
![]() Join Date: Dec 2001
more than likely your ground is too long from your amp. Shouldn't be more than about 8in. Grounds are notorious for picking up engine noise. The longer they are the more likely it will happen
sykik, u da man.. ur right, mine is really long right now.. I'll make it short!.. sweet duude..
and i used sweet fosgate rca shit.. soo expensive.. so it must be the ground, also, i ran the power down the other side of the car so that can't be the problem. |
WOW addicted
My roommate also said that The ground should be at least 12in or so from the Power cable. He also said the ground shouldn't matter.. (doh.. opps) He said if you have noise it should be from RCA's even nice cables sometimes get it.
He said there are filters you can buy for the RCA's. He also suggested that it may be your amp. (Edited by sykikchimp at 6:37 pm on Feb. 21, 2002) |
![]() Join Date: Jan 2002
Hey man,
The ground wire can definatley make a difference in the noise in a system. Make sure that where you have grounded has been filed so it goes to bare metal (no painted or otherwise finished surfaces..) RCA cables are generally the last things in a system that cause noise, so if you bought decent ones you're fine. Unless they are directional... and hooked up backwards.. that isn't really the best way to go. I work in the audio industry, so I'm somewhat experinced in cleaning up noise problems. Since it's a quality (or at least not shitty) you can bet it's probably in the ground... shorten it up and make sure it's clean where you screw it in! ( A good thing to do in all aspects of life ) Jeff |
lol , thanks jeff <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'> (words of wisdom "make sure it's clean where you screw it in" <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> )
i'll let ya all know how it goes, i'll try to fix it tomm.. also, anyone have a good idea on where to mount a pretty small amp at in the trunk? |
One other thing that will cause noise is if you ran the power wire to your amp alongside your RCA cables. It'll attract the + voltage. It's best to have them on opposite sides of the car.
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from AJ on 4:21 pm on Feb. 21, 2002
i ran the power down the other side of the car so that can't be the problem. </td></tr></table><span id='postcolor'> <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> yeah, i knew that caused problems.. so i did do them seperate.. |
Sometimes the amp isnt compatable with the speakers/headunit which causes a huming/buzzing sound. I had the same problem with my Rockford amp & Clarion speakers. Just get a noise filter, put it btwn the RCAs and the amp-problem fixed.
