Old 09-04-2010, 03:17 PM   #1
hacknik
hacknik's Avatar
hacknik is an unknown quantity at this point
H.U.D and Sunroofs
I'm planning on getting a new chassis, but have a few questions.
S13's --
Is it only the USDM version's that came with digital H.U.D? I've yet to see a Silvia with one.
Also, is it possible to install/retrofit one in (either a USDM hatch, 180, Silvia)? (Yes I used the search button)
S14's --
Do all models (Kouki + Zenki) come with electric retractable sunroof's? (or was it just the SE/LE etc..)
Are there any that actually came with HUD from the factory?
I loves OEM digi bling
Shit is WET
hacknik is offline   Reply With Quote
Old 09-04-2010, 10:18 PM   #2
Sam_Well.13
Sam_Well.13 is an unknown quantity at this point
S13.. i dont recall Silvia coming with HUD.. regardless.. HUD is readable both KMH and MPH.
yes it is possible, but its not really retrofitting, everything is plug and play with the harness. Depending what motor you have, SOHC or DOHC, you have to change the RPM face gauge. and speed sensor.
Sam_Well.13 is offline   Reply With Quote
Old 09-04-2010, 10:26 PM   #3
Wake
Wake's Avatar
Both S13 and S14 silvias came with HUD and digi dash, all generations. Only USDM S13s came with HUD.
Yes it is possible to retrofit any HUD into any S-chassis as long as you have the correct generation parts. VSS, gauge cluster and accompanying wiring. You didnt use the search button very well.
Once again (for the third time) all JDM generations came with OEM HUD (meaning from the factory). Only USDM S13s came with HUD.
I dont know the S14 sunroof answer, and this didnt need its own thread.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 09-05-2010, 09:08 AM   #4
sil80d
sil80d is an unknown quantity at this point
you can use any s13 vss with the hud system. my coupe has a hud, it was an auto when i got it, then i swapped and non huds manaul trans into it, and just recently a dohc non hud motor set into it. in all three versions the hud has worked flawlessly
sil80d is offline   Reply With Quote
Old 09-05-2010, 11:22 AM   #5
h2v7
h2v7 is an unknown quantity at this point
dont you need a special windshield with that little etched area for hud to display on?
h2v7 is offline   Reply With Quote
Old 09-05-2010, 11:38 AM   #6
Krimlin
Krimlin's Avatar
Krimlin is an unknown quantity at this point
S14 JDM came with HUDs. USDM no.
All USDM S14 models came with a sunroof option.
Krimlin is offline   Reply With Quote
Old 09-05-2010, 02:22 PM   #7
Wake
Wake's Avatar
Your Dumb
Thats because you had the correct generation gauge cluster and VSS, which is exactly what I said. It worked every time because you used a 91-94 VSS in a 91-94 chassis, with a 91-94 gauge cluster and ECU. duh
You dont NEED it but its much better to have IMO its fuzzy on a regular windshield, some people just put a square of light tint instead.
OEM replacement windshield is $3k+, no matter where you get it.
Didnt I say that like 3 times?
S.P.P.S. Member #00
Old 09-05-2010, 03:27 PM   #8
Krimlin
Krimlin's Avatar
If someone asked the question I'm sure they won't get it till you say it 5 times so I saved you 1 time
Old 09-05-2010, 07:40 PM   #9
h2v7
where do i get a windshield without the fuzzy they are not 3k are they!?
Old 09-05-2010, 08:30 PM   #10
Wake
Wake's Avatar
yes if you want a new your looking at $1500 alone for just the windshield and thats wholesale then your going to have to pay the markup of whoever got it for you.
Check that I just looked at courtesy parts and they have them for $700 but your still going to have to pay shipping for a windshield from TX which is 100 bucks tro my zip in nor-cal. SO looks like one can be had for $8-$1000
S.P.P.S. Member #00
Old 09-06-2010, 05:44 PM   #11
hacknik
hacknik's Avatar
LOL, anyways, thanks for the reply sir. If your mad because of my question with it's multiple same approach, then be mad. There are more then enough clowns on this forum, I just wanted to make sure I asked what was on me mind the first time around.
And yes, this does deserve it's own thread. I've yet to see a dedicated thread about H.U.D's, not scarce info.
Shit is WET
Old 09-06-2010, 03:43 PM   #12
h2v7
so WTF do i do with a cracked windshield?!?!
make my insurance cover it?
Old 09-07-2010, 04:02 PM   #13
joeboo1
joeboo1's Avatar
joeboo1 is an unknown quantity at this point
the jdm s13 did have the HUD it was the A's model
joeboo1 is offline   Reply With Quote
