Old 10-28-2010, 07:48 PM   #1
lv240s14
lv240s14 is a jewel in the roughlv240s14 is a jewel in the roughlv240s14 is a jewel in the roughlv240s14 is a jewel in the roughlv240s14 is a jewel in the roughlv240s14 is a jewel in the roughlv240s14 is a jewel in the rough
Send a message via AIM to lv240s14
FS: 3071 Full Race kit, Build sr20det, Maxworx sr-z32 trans setup and more
Parting out my sr setup.
This setup helped me alot this year and because of it I didn't miss a single event. Everything I put in my car is quality parts and it shows in power and realiblitiy. Events suck when you have to fix things over and over again. Do it right the first time.
3071 Full Race sr20det kit $2500
Full race T3 twin scroll manifold
Full race mid pipe
Garrett 3071 twin scroll Turbo
Tial 44mm waste gate w/ 1 bar spring
T3 turbo blanket
-6 coolant lines
-3 oil line with reducer
-10 oil drain line
4 inch intake with filter
All lines are heat wrapped
5 layer s15 exhaust gasket
twin scroll turbo gasket
Built sr20det $2000
Stock crank with OEM nissan bearings
Eagle rods
CP 9.0:1 compression pistons
Cometic Headgasket
HKS 264 step 2 cams
Greddy Rocker Arm stoppers
peak performance valve springs
When the motor was put together Other new oem parts where used like:
Oil pump
Thrust washers
timing chain tensioner
timing chain
valve seals
Motor oil has been changed everyother event and I have only used synthetic 15-50 to keep the bearings nice and fresh.
Maxworx sr to z32 transmission adapter kit with z32 transmission $1500
Maxworx adapter plate w/ hardware
Mazworx shifter braket w/ shifter
Mazworx driveshaft
z32 Transmission in perfect working order
Competition clutch twin disk used for about 9 events. $700
Still has lots of life on it. This is a picture of it when it was new
Power FC with commander d Jetro with map sensor- 1000
SR20 engine wiring harness with voltage reducers for rc injector- 200
Splitfire coilpacks- 400
RC engineering 1200cc Injectors with plugs- 500
Top feed fuel rail- 100
Sard FPR- 150
Mid mount intercooler made for oem intake manifold and top mount turbo w/ tial BOV Includs all t bolt clamps and couplers- 500
S13.4 valve cover- 300
Greddy oil pan– 200
Derale oil cooler w/ fan block adapter and all lines- 400
ATI super Dampener- 300
Stance water pump pulley- 100
SR alternator rebuilt to put out 120 amps instead of usual 80 amps- 160
Power steering pump with high pressure line and cooler- 200
Oem intake manifold polished w/ thermo intake manifold gasket- 150
More pictures and items will be posted in the next few days. I am willing to negotiate with the prices and the more you buy the more I will reduce the price.
I am willing to ship at the buyers expense.
Autobodylv.comworldhookah.com
endura-tech.comvegasdrift.com
lv240s14 is offline   Reply With Quote
Old 10-28-2010, 08:40 PM   #2
alex_s817
alex_s817 is making his/her stupidity well-knownalex_s817 is making his/her stupidity well-knownalex_s817 is making his/her stupidity well-known
bump for a good guy, met you at dougs once, all very nice parts here
alex_s817 is offline   Reply With Quote
Old 10-28-2010, 09:54 PM   #3
Om1kron
Om1kron's Avatar
jizz on that z32 trans setup.
Wayne Edwards
https://om1kron.blogspot.com
Old 10-28-2010, 10:21 PM   #4
lv240s14
It works amazingly well. After drifting with this trans setup I realized how bad sr transmissions are.
Old 10-29-2010, 12:48 PM   #5
240knockout
240knockout's Avatar
240knockout is an unknown quantity at this point
On the turbo kit:
approximate use/miles? is that $2500 inclusive of shipping?
240knockout is offline   Reply With Quote
Old 10-29-2010, 07:07 PM   #6
lv240s14
Originally Posted by 240knockout View Post
On the turbo kit:
11 events old, never street driven. I never boosted over 18 psi when driving on it. I boosted it to 21psi once to tune the car but thats it.
2500 plus shipping depending on where you live and how much shipping is.
Old 10-29-2010, 09:15 PM   #7
JRwerks
JRwerks's Avatar
Trader Rating: (55)
JRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of light
Feedback Score: 55 reviews
Awesome setup!! How's the gearing ration on the Z tranny for the SR? More top end? Acceleration?
JRwerks is offline   Reply With Quote
Old 10-29-2010, 11:33 PM   #8
lv240s14
Actually it was close to the same. I noticed no difference in top end or acceleration. The only thing I noticed is a strong feeling transmission that I could upshift without feeling the trans was going to blow. This thing is rock solid and strong.
Old 10-30-2010, 12:20 AM   #9
Z350MAN
Z350MAN is an unknown quantity at this point
i have same trans setup,, feels a little longer geared to me.. depends on the rear end you are using. if you have 4:08 r32 or 4:10 z32 it should be around the same as Sr trans and J30 with the 3:91.
Z350MAN is offline   Reply With Quote
Old 10-30-2010, 01:15 AM   #10
lv240s14
http://ep.yimg.com/ca/I/phase2motors...2127_123169747
according to this they are about the same and to me it feels the same. I don't know how much .023 in second gear out make.
Old 10-30-2010, 02:17 AM   #11
imnotniko
imnotniko is an unknown quantity at this point
willing to sell the turbo kit with everything minus the turbo? if so please let me know. thanks
imnotniko is offline   Reply With Quote
Old 10-30-2010, 04:10 PM   #12
solow240
solow240 is an unknown quantity at this point
pm sent, on trans set-up..
solow240 is offline   Reply With Quote
Old 10-30-2010, 09:30 PM   #13
vqboodah
vqboodah's Avatar
vqboodah is on a distinguished road
what head gasket thickness did you run and what did you run for boost on your setup?
vqboodah is offline   Reply With Quote
Old 10-30-2010, 09:46 PM   #14
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Awesome Turbo set up... good price..
GLWS
Old 10-31-2010, 04:44 PM   #15
lv240s14
I ran a 1.1mm headgasket. I tuned the car for 21psi but never ran that much. I ran 18psi during the season because of the smaller courses I ran on didn't need the extra power.
Old 11-12-2010, 06:48 PM   #16
lv240s14
trans setup is sold
Old 11-16-2010, 11:35 PM   #17
lv240s14
clutch, power fc, wiring harness, splitfires, injectors and fuel rail sold.
Old 11-16-2010, 11:41 PM   #18
swat310
swat310 is an unknown quantity at this point
Will you part with the
Tial 44mm waste gate w/ 1 bar spring?
pm me if so thanks
swat310 is offline   Reply With Quote
Old 11-26-2010, 09:09 PM   #19
UNT 240
UNT 240 is an unknown quantity at this point
How much is left of the motor swap, very interested? What would the shipping b to 75189?
UNT 240 is offline   Reply With Quote
Old 12-02-2010, 12:07 AM   #20
lv240s14
sorry for the late update but turbo kit is sold.
motor and accessories still up for grab. I suggest getting everything as a whole for a discounted price.
midmount is still for sale too.
pm me don't post on the thread if you guys want something it's easy for me to see if someone wants something that way
3071, full race, sr20det, z32
