Old 10-31-2010, 02:09 AM   #1
ship2236
ship2236's Avatar
Trader Rating: (18)
ship2236 is making a name for him/her selfship2236 is making a name for him/her self
Feedback Score: 18 reviews
Send a message via AIM to ship2236
Headlight problems~ need help plz
K so im sure the answer is out here sonewgere but i cant seem to find it. I have a 91 coupe, chukie front with a 600k hid conversion... My problem aside from the fact both headlights go down and only 1 pops back up is that they don't turn on or illuminate anymore period n they just worked last nite. The bulbs r good because they r brand new. I have pulled relays n swapped with a friends to see if that wad a possibility n nothing. All fuses ate good. All conections are good. I'm at a loss. I even pulled the switch from the Colum n Followed this complete write up and nothing.....
how to fix your headlight problems : 240sx General Discussion
any ideas plz let me know!
Thanks!
ship2236 is offline   Reply With Quote
Old 10-31-2010, 02:31 AM   #2
TachPHD
TachPHD is an unknown quantity at this point
I had the same issue. First was the motor on the passenger side not going up, but it would retract downward. Solution: turned out to be a fried wire right by the motor itself and into the circuit board inside. Second was no hid's. Solution: No idea, just pulled everything and reconnected the system, checking all grounds and power.
So check the motor wires and reconnect your hid's? Good luck man.
TachPHD is offline   Reply With Quote
Old 10-31-2010, 11:46 AM   #3
ship2236
ship2236's Avatar
Trader Rating: (18)
Thanks man I'll give that a try. Just finished my bowl of wheeties.... It's time to get cracking on this 
Old 11-01-2010, 10:29 AM   #4
auk113
auk113 is an unknown quantity at this point
i just went through a simmilar issue, turned out to be headlight switch it self. as retarted as it is
auk113 is offline   Reply With Quote
Old 11-01-2010, 11:37 AM   #5
ship2236
ship2236's Avatar
Trader Rating: (18)
Yea I pulled it apart n polished all the connectors n butt conectors and nothin, tried my buddies switch from his hatch n nothin either so idk. Also I check to see if it was even getting power to the sockets and everything checked out. It's crazy
Old 11-01-2010, 12:07 PM   #6
klits562
klits562 is an unknown quantity at this point
Did you check the grounds for the motors?
I had a similiar problem where one headlight would go down but not up and the other would go up not down. I replaced the combo switch on the steering column, the switch next to the column, all the relays, and nothing, i finaly changed the motors and got it working, with just a little glitch.
klits562 is offline   Reply With Quote
Old 11-02-2010, 09:52 PM   #7
ship2236
ship2236's Avatar
Trader Rating: (18)
Still no resolve. I sanded down the contacts for the grounds for the motors and nothin. I can hear them trying to work. This is lame
Old 11-04-2010, 02:53 PM   #8
ship2236
ship2236's Avatar
Trader Rating: (18)
Anyone else have any ideas? I just tested my ballast's from the battery n they lit up n r working fine! New combo switch on the colum! And still ain't got 
Old 11-13-2011, 06:46 PM   #9
Nemo
Nemo is an unknown quantity at this point
I kinda have kinda the same problem but mines are stock and both do come up and go down with no problem but the headlights are the only thing that doesn't come on. rear ones do, cluster, and all the other light but the headlight.
checked all the fuses and switched them around and all that fun stuff but nothing yet ill try taking the switch off and cleaning it or trying someone else's and see what happens and ill let you know
Nemo is offline   Reply With Quote
Old 11-13-2011, 10:50 PM   #10
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
your gonna have to start tracing the power path. start at the headlight plug and work towards the switch. if you have no power to the headlight plugs, then check the relays, no power to the relays, check the fuses, no power to the fuses, check the switch.no power to the switch, you have a break in the wiring. good luck
rcdad123 is offline   Reply With Quote
Old 11-14-2011, 10:15 AM   #11
ship2236
ship2236's Avatar
Trader Rating: (18)
Lol super old thread man. Problem was fixed long ago! Thanks anyways though
Old 11-14-2011, 04:25 PM   #12
Nemo
lol man i didnt even notice the 2010 haha but what was wrong with yours and i just noticed that one of the headlights is cracked(prob a rock on the highway or something) could that stop both of them?
Old 11-15-2011, 10:26 PM   #13
ship2236
ship2236's Avatar
Trader Rating: (18)
Ended up being the headlight/turn signal switch. Turn signals still worked as didthe rest of the running lights( just not the head lights). Decided to pocket one at the junkyard only because it was nice and had no sun damage, swapped it on and everything worked again
