FS: NY S13 SR20DET Blacktop part-out!!!
Well, I was running MSD 72lb injectors on my sr and one of them failed, causing a lean condition in cylinder 2, which damaged the water jacket in cyl two. For all intensive purposes, the block is not salvageable. However, everything else is in great working order. Everything is for sale except for the CAS. I have everything else including:
-Stock T25 (in EXCELLENT condition) *SOLD* -Valve cover (small dent from leaving a tool on it and closing the hood) *SOLD* -3 coilpacks (one of the 4 is badly cracked) $25 (each) -Coilpack harness $30 -2 knock sensors *SOLD* -O2 sensor *SOLD* -MAFS $35 -coolant temp sensor $10 -Wiring harness (not the greatest I've seen) *SOLD* -Lower trans harness $50 -2 sets of stock cams $40 (each) -Stock exhaust manifold $25 -T25 with blown seals [I think] $40 -alternator $30 -2 sets of stock fuel injectors, rails and FPR's $115 (each) -ARP head studs (used for about 1000 miles, probably less) $75 -Transmission *SOLD* -water pump*SOLD* -oil pan $20 -timing chain tensioner $30 -Head (Looks excellent, but might need machining) $150 -bottom end (pistons and other components are in *GOOD* condition) (make an offer) -Fidanza flywheel *SOLD* -ACT 6 puck unsprung clutch (good condition) $140 -Stainless steel turbo lines (t25, t28) $60 -Passenger side door w/ mirror and door card (s13, primered black, crank windows) $65 (picked up) -Electric driver side mirror $20 -Stance GR+ Pro springs (2 8kg front, 2 6kg rear) $50 I'm getting tired of listing things, so if you need something, just ask. I most likely have it since I have a complete swap basically. Ask for pictures if you want them. Email is the best way to get in touch. [email protected] All prices are OBO Last edited by s13pimp; 01-06-2011 at 03:12 PM.. Reason: Added new item! |
For all that asked, I'm located in Syracuse, NY.
Pics of flywheel: ![]() ![]() The friction plate is a little rusty. It could be resurfaced, or you could simply order a new friction plate for $61, and then you would have a brand new flywheel. |
#16 |
#19 |
Sorry for the delay, but here is a picture of the clutch.
![]() And sorry, but I have no radiator for sale. I have only one manifold left, and I actually dont think it has a heat shield. I can check tomorrow though. |
#20 |
![]() Join Date: Dec 2008
![]() Feedback Score: 7 reviews
where is dent on valve cover? picture?
and would you be interested in selling just the compressor wheel off that t25... otherwise cause i know you dont wanna fuck with that snap ring.... make that t25 $30 shipped to DE 19713 and you got a deal.... and depending on location of the "dent" i might take valve cover too.
"soft so you can't even enjoy it" |
#29 |
