Old 12-18-2010, 09:14 PM   #1
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
RB25 arp stud installation ?
Ok I just want some feedback on the installation of my arps head studs on my rb25.So after reading arp's instructions it says to install the studs hand tight(into the block) and to apply the provided lubricant on the washer studs and washers and to tighten in 3 equal steps to 80ft/lbs per fsm spec. Now what I did is install the studs hand tight into the block with no lube on the block side of the stud, drop the head onto the block, apply lube to the washers and the inside of the nut and torqued it down to 26ft/lbs then 52, and finally 80. I am the paranoidal type so i called arp to verify and he said I installed it correctly but i want a second opinion before I drop the engine into the car. Did I install it correctly?
redline racer510 is offline   Reply With Quote
Old 12-18-2010, 10:01 PM   #2
redline racer510
back to the top of the list please
Old 12-18-2010, 10:10 PM   #3
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
did you put moly lube on the threads before you hand tightened the studs into the block ?
other then that it sounds like you did it right.
1992 240sx (RB20. 362whp@16psi)
eklips3 is offline   Reply With Quote
Old 12-18-2010, 10:20 PM   #4
redline racer510
The threads that went into the block didn't get any lube. Would it be safe to leave the head on the block and remove the studs and redo everything ? I knew you had to put lube on the threads going into the block but I listened to the arp dude. Yes he told me to only put lube on the side that the nuts go on to.
Old 12-19-2010, 09:32 AM   #5
redline racer510
would it be safe to remove and retry with same headgaasket?
Old 12-19-2010, 10:30 AM   #6
redline racer510
can someone please chime in?
Old 12-19-2010, 11:00 AM   #7
redline racer510
come on dudes(and gals)
Old 12-19-2010, 11:31 AM   #8
R33E8
R33E8 is an unknown quantity at this point
You are fine, you don't need lube on the threads that go into the block (just tighten till they stop finger tight or so).. Only the threads with the nut and washer need lube..
R33E8 is offline   Reply With Quote
Old 12-19-2010, 11:35 AM   #9
redline racer510
O ok cool whoooooooo man that was a relief. I was afraid I had to buy new gasket and had to do everything over again thanks man we can shut this thread down,
Old 12-19-2010, 05:18 PM   #10
nismoman
nismoman is an unknown quantity at this point
Yeah you did it right man. You just don't want the nut binding while you torque them, gives you a false reading
nismoman is offline   Reply With Quote
Old 12-20-2010, 04:52 PM   #11
redline racer510
do you guys think i should remove the nuts and apply lube to the stud threads?
Old 12-20-2010, 06:42 PM   #12
nismoman
No no no. You did it properly
