Old 01-03-2011, 10:41 AM   #1
pink godzila
pink godzila's Avatar
Trader Rating: (226)
pink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond repute
Feedback Score: 226 reviews
ECU Question on KADE 97~98
It is ok to use 98 manual ECU on a 97 manual?
Also what number is for 97 manual ECU and 98...
J6?J7?3T.....etc
pink godzila is offline   Reply With Quote
Old 01-03-2011, 04:39 PM   #2
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
Here You Go!
"ECU Swapping:
In order to get rid of the CEL (which would have prevented the car from passing OBDII testing when the car is inspected), a Manual ECU was used. Once the new ECU was installed, there was no CEL and no more rough starts – the car behaves exactly the same as a stickshift that came out of the factory. The Manual ECU can be used with the automatic transmission wiring harness.
If your car is a ‘95 the new ECU must be from a ‘95 (maybe 96?)
If your car is a ‘96 the new ECU must be from a ‘96 (maybe 95?)
If your car is a 97-98, the new ECU must be from a 97-98, or you can repin a 95-96 ECU to work in a 97-98 240sx (which is what we did on Matt’s car). In order to repin it, follow the link here:
http://jimwolftechnology.com/w…D.PDF
Once it is repinned, you may need to buy a new rear O2 sensor in order to clear all CELS (that is mentioned in the link)"
Retrieved from How to install a manual transmission in a 240sx
essforteen is offline   Reply With Quote
