Old 01-08-2011, 11:27 PM   #1
brudacille
brudacille's Avatar
brudacille is an unknown quantity at this point
s14 Lower Wiring Harness Help Please!!!!
How the f*ck is this suppose to work? I know its wrong, just tell me how it's suppose to work. Your looking at a 1995 S14 OBD1 Wiring Harness and a KA24DE Starter.
brudacille is offline   Reply With Quote
Old 01-08-2011, 11:35 PM   #2
S14DB
AFC #1
S14DB's Avatar
You have your alternator hooked up?
Old 01-08-2011, 11:40 PM   #3
brudacille
brudacille's Avatar
Alternator looks like this..... I'm still not sure what the 2 red wires (looks like they were spliced into the upper harness) are for yet. Could they be for the alternator?
It's 1:47am.... I'm going to bed. I'll respond to everyone in the AM
Old 01-09-2011, 10:59 AM   #4
brudacille
brudacille's Avatar
Bump!!! I would like an idea b4 I go to the garage and continue.....
Old 01-10-2011, 02:42 PM   #5
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
looks like the OEM wire that goes from starter to battery, that usually companies half ass and don't replace and just lay another wire on top. take pic of where the wire leads to.
Review Thread
bardabe is offline   Reply With Quote
Old 01-10-2011, 03:02 PM   #6
180wanabe1
180wanabe1 is an unknown quantity at this point
please tell me You didn't put the battery in the trunk cause that is the most half assed job i've ever seen, bar none! the two wires you have on the starter should not be on there they should be connected together in a totally different way and the wire that you don't know where it goes should be on the starter solenoid.
180wanabe1 is offline   Reply With Quote
Old 01-10-2011, 10:38 PM   #7
brudacille
brudacille's Avatar
Thanks for the responses.... Everything was figured out and cleaned up today
alternator, harness, solenoid, starter, wiring
