Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Forced Induction
Old 01-12-2011, 12:59 PM   #1
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
GodSpeed TD05 18G and TD06 20G Bottom Mount Turbo (Direct Bolt On)
Godspeed TD05 18G and TD06 20 Bottom Mount Turbo
Both Driect Bolt on SR20 Redtop and Blacktop
TD05 18G on the Left and TD06 20G on the Right
TD05 18G
TD05 18G Turbo Spec.
Bearing system: Journal Bearing
Compressor Wheel Diameter: 50.3 / 68mm
TURBINE Wheel Diameter: 49.2 / 56mm
Turbine TRIM: 57
Turbine flange type flange: T25
Downpipe flange type : 240sx 5 bolt type
Nozzle Area: 8cm²
Cooling type : oil and water cooled.
Horsepower rating: 300-380 hp
BOLT ON TURBO FOR S13 S14 S15 (SR20 MOTOR)
Actuator set at : 14.5 PSI
CFM: 600
Mod on our Time Attack 240SX, SR20 Redtop Stock with HKS CAM, Godspeed Intake Manifold , Turbo Manifold , Turbo Back Exhuast , Stock Piston and Rods
YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 1st Pull
YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 2nd Pull
YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 3rd Pull
YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 4thd Pull
more info. please check
http://zilvia.net/f/tech-talk/323337...dyno-test.html
TD06 20G
This is on a Black top S14 with 650cc injector , stock internal and 14.5 psi.
TD06 20G Turbo Spec.
Compressor Wheel Diameter: 58.8 / 68mm
TURBINE Wheel Diameter: 58.8 / 67.14mm
Turbine TRIM: 57
Nozzle Area: 8cm²
Horsepower rating: 400-450 hp
CFM: 640
No Restrictor need for oil feed line
TD05 18G
$330 Shipped (Lower 48 State)
$362.17 Shipped/Taxed (CA Customer)
$310 Pick Up Preferred Cash
TD06 20G (In Stock!!!!
$450 Shipped (Lower 48 State)
$493.87 Shipped/Taxed (CA Customer)
$430 Pick Up Preferred Cash
Please PM for Payment Method.
Fatboy Garage Motorsport Inc
GODSPEED Project
2518 Continental Ave
El Monte CA 91733
P: 626-442-3988 ask for Ken
W:godspeedproject.com
Fatboy Garage is offline   Reply With Quote
Old 01-12-2011, 03:34 PM   #2
projectslider
projectslider is an unknown quantity at this point
fawk!! these are to good to be true!!
are these dependable for a full drift car!?
let me know shipped for an 20g to zip 00926!
projectslider is offline   Reply With Quote
Old 01-12-2011, 07:41 PM   #3
gunluvS14
gunluvS14's Avatar
gunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura about
this is direct bolt on and everything line up?
wow, not bad
http://www.zilvia.net/f/image.php?type=sigpic&userid=45706&dateline=118722  3315
gunluvS14 is offline   Reply With Quote
Old 01-12-2011, 10:20 PM   #4
r34sr
r34sr is an unknown quantity at this point
YES! i will definitely be running the 20g this summer for my KA24 build.....if those dyno numbers are for sr20's imagine what a KA will put down.
r34sr is offline   Reply With Quote
Old 01-13-2011, 02:10 AM   #5
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
In regards to the TD06 20G...will it bolt up to a KA-T bottom mount T25 manifold without clearance issues? Also, does it use the standard SR turbo elbow?
Also, is that actuator adjustable..? Looks like it.
Originally Posted by KoukiMonsta
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
StryfeS13 is offline   Reply With Quote
Old 01-13-2011, 02:59 PM   #6
TheRealSy90
TheRealSy90's Avatar
It's an adjustable actuator and uses the typical 5bolt exhaust elbow from the factory sr turbos.
Such a good signature.
Old 01-13-2011, 03:02 PM   #7
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
Will there be any fitment issues with the 20g on an sr20 swap. I cant wait till you guys mount this to one of your guys track cars. Please let us know how the fitment is. Does it hit the motor mount?
BX|Photo
LS400 - Slammed | Fitted | Loud
SuicidnS13 is offline   Reply With Quote
Old 01-13-2011, 05:47 PM   #8
Fatboy Garage
Here is the Picture of the flange that we have, so you can use after market intake and intercooler
This set is $40 Shipped
Thanks
Ken,S
Old 05-23-2011, 12:29 PM   #9
clay9110
clay9110's Avatar
clay9110 is an unknown quantity at this point
Thanks
Ken,S
Ken,
This is what I pm'd you about. You quoted me at 70 shipped when u have it listed here for $40...
clay9110 is offline   Reply With Quote
Old 05-23-2011, 02:46 PM   #10
Fatboy Garage
Originally Posted by clay9110 View Post
Ken,
yea cause your pm said you need the one same as riley , this is not the same one actually , we dont have the elbow anymore, we only have the one connect that intake, and that one is $25 shipped
Old 01-13-2011, 07:40 PM   #11
SuicidnS13
SuicidnS13's Avatar
So your saying the factory inlet and outlet of my t28 will not bolt up? Or are these clocked differently?
BX|Photo
Old 01-13-2011, 09:44 PM   #12
Allmtoreg
Allmtoreg is an unknown quantity at this point
same question for for t25 outlets?
Allmtoreg is offline   Reply With Quote
Old 01-14-2011, 12:28 PM   #13
Fatboy Garage
no the Stock one will work, everything bolt on but if you have after market FMIC you might need to change the adapter depend on what kind of kit you have.
Thanks
Ken,S
Old 01-14-2011, 09:51 AM   #14
projectslider
still waiting for my shipping qoute!!
Old 01-16-2011, 09:34 PM   #15
Moon Ill
Moon Ill is on a distinguished road
Is it ok to run the 18G without the water lines?
Moon Ill is offline   Reply With Quote
Old 01-17-2011, 12:00 AM   #16
norcal_black240
norcal_black240's Avatar
norcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud ofnorcal_black240 has much to be proud of
Send a message via AIM to norcal_black240 Send a message via MSN to norcal_black240
Any warranty with these?
Which country are the turbo's made?
norcal_black240 is offline   Reply With Quote
Old 01-17-2011, 01:03 PM   #17
Fatboy Garage
no is not ok to run it without water, turbo will not cover by warranty.
1 year warranty as long as the turbo is installed by ASE Cerf. tech , turbo is made over sea.
Thanks
Ken,S
Old 01-19-2011, 05:13 PM   #18
Moon Ill
Thanks
Ken,S
That is fair enough.
I'm going to shoot you a PM about something.
Old 01-18-2011, 10:26 PM   #19
90hatchie
Banned from the Marketplace
im ase certified
so if it blows up on me your gonna honor my certification?
90hatchie is offline   Reply With Quote
Old 01-19-2011, 10:55 AM   #20
Fatboy Garage
Originally Posted by 90hatchie View Post
im ase certified
Yes of course, as long as you have a copy of certificate we will give you a warranty exchange no question ask.
Thanks
Ken,S
Old 01-20-2011, 10:55 AM   #21
Fatboy Garage
All Pm Sent!!!!
Old 01-25-2011, 07:53 PM   #22
Fatboy Garage
All Pm Sent!!!!
Old 01-25-2011, 11:22 PM   #23
SuicidnS13
SuicidnS13's Avatar
Price on a package deal of
Turbo Manifold (t25 bottom mount)
Turbo Elbow (Screamer)
tdo5-18g turbo
shipped to 89031 please
thanks
BX|Photo
Old 01-26-2011, 10:52 AM   #24
Fatboy Garage
All Pm Sent!!!!
Old 01-26-2011, 12:44 PM   #25
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
Go 20G.
Any future for a Evo-III style 16G or Ball-Bearing options?
Corbic is offline   Reply With Quote
Old 01-26-2011, 01:12 PM   #26
Fatboy Garage
Go 20G.
Sure dont have both of the option.
Thanks
Old 01-26-2011, 10:27 PM   #27
mikey_S13
mikey_S13 is an unknown quantity at this point
any updates on on the time attack 240 running the new 20g?
..has anyone else installed the 18g?? i have mine sitting on my room. im still gathering few more parts till i put it in and im curious to how the setup is with anyone else?!
mikey_S13 is offline   Reply With Quote
Old 01-27-2011, 10:21 AM   #28
Fatboy Garage
we should have an update around March.
Old 01-31-2011, 10:51 AM   #29
Fatboy Garage
all pm sent!!!
Old 02-04-2011, 10:37 AM   #30
tx240ss
tx240ss is an unknown quantity at this point
need advise on TD06
About two years ago I bot a Greddy kit to turbo my ka motor with 150lbs compression on all four cyl and it ran great until last month when it blew rings in #2. dyno pulled 275whp..@6000rpm. Bot a red top SR and have all the Greddy bits. now the questions:
1. can I run the td06-20g on the SR.
2. how big of injectors should I run? Now 370s
3. can I use the e-manage system? will it have to be reprogrammed?
4. How much more power could I expect over stock running at 8-10lbs boost?
5. Whats the best manifold to get?
current set up
3 " exhaust
FMIC
TD06-20g
370s
fuel rail
walpro fuelpump
z32 maf
emanage
tx240ss is offline   Reply With Quote
