Old 01-19-2011, 01:28 AM   #1
mike fonseca
mike fonseca's Avatar
Trader Rating: (43)
mike fonseca is an unknown quantity at this point
Feedback Score: 43 reviews
help please i cant figure it out :((
I have a s13 with a ka24de my car runs perfectly fine n idle fine as well but as soon as I go in the free way or any time I go past 4k rpm the car bogs out it jerks back n toward n won't go past 4500-5000 rpm just jerks back n toward till I let go of the gas I've changed the fuel pump ,knock sensor,o2 sensor, I cleaned the maf n the tps n still nothing Idk what could be wrong with it some one please help me (
mike!
mike fonseca is offline   Reply With Quote
Old 01-19-2011, 02:15 AM   #2
lexlaxlux
lexlaxlux's Avatar
Trader Rating: (32)
lexlaxlux is an unknown quantity at this point
Feedback Score: 32 reviews
Did you check your timing? Upgrade cams? Anything you did to the motor before the problems had begun?
lexlaxlux is offline   Reply With Quote
Old 01-19-2011, 02:21 AM   #3
mike fonseca
Trader Rating: (43)
No timing is good n no motor is bone stock problem just came out of no where I did a full tune up n still bogging won't go away n I have no check engine light ether
mike!
Old 01-19-2011, 02:31 AM   #4
lexlaxlux
lexlaxlux's Avatar
Trader Rating: (32)
NO CEL usually indicates you might have something minor affecting a larger counterpart
I would suggest to you if you say that everything listed above had been checked--
-Recheck your Fuel pump and check for metal shavings around the filter
-Grab a friend and have him turn on the car.. Rev it up as you wiggle the engine harness for any shorts or bad connections
-If worse comes to worse pop off that valve cover and start looking inside.
-Rocker arm (shim buckets) & chain guides... notorious KA's
these all could be possible factors but it really comes down to everything you check and if you can eliminate all the non-existent problems
if its not electrical and something minor top end then SOL.
Old 01-19-2011, 02:33 AM   #5
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
IACV. try to clean that.
@dangerdamian
STEEZxIT is offline   Reply With Quote
Old 01-20-2011, 01:19 AM   #6
mike fonseca
Trader Rating: (43)
Ima try that thanx guys
mike!
Old 01-20-2011, 09:18 AM   #7
nismoman
nismoman is an unknown quantity at this point
Sounds like an ignition system problem. Check coil ,distributor cap, rotor, plugs and wires
nismoman is offline   Reply With Quote
Old 01-20-2011, 09:49 AM   #8
slider2828
slider2828's Avatar
Sounds like that or a FPR problem.....
Turn and Burn!
Old 01-20-2011, 10:25 AM   #9
Kiro1968
Kiro1968's Avatar
Kiro1968 is an unknown quantity at this point
Since you replaced some components already, follow the Service Repair Manual and test the Camshaft Position Sensor, Crankshaft Position Sensor and MAF (actual test and not just cleaning it)
1995 240sx SE 5spd Red/Black
1993 240sx 5spd Coupe Red (SOLD)
Kiro1968 is offline   Reply With Quote
Old 01-20-2011, 03:00 PM   #10
murffy
murffy's Avatar
Trader Rating: (44)
murffy is an unknown quantity at this point
Feedback Score: 44 reviews
yea check the iavc and the voltage of the injectors and if ur injectors are good u might be running lean cuz of injectors being dirty or done put an after market fuel pump
murffy is offline   Reply With Quote
