Old 01-19-2011, 11:40 PM   #1
nujabe
nujabe's Avatar
nujabe can only hope to improve
break idle hesitation problem PLEASE HELP!!!
to start first off im running z32 breaks up front and stock s14 rears.
i have a stock s14 bmc.
I changed the rear pads today and after i bleeded them i seem to have this weird problem that i never seen before .
when the car is idle and i break and keep breaking it seems to hesitate a good mount almost feels like it wants to choke the engine. btw im running an s13sr
I WILL ANSWER ANY QUESTIONS thanks.
nujabe is offline   Reply With Quote
Old 01-19-2011, 11:46 PM   #2
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
sounds like you need to clean your idle control valve.
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 01-20-2011, 12:27 AM   #3
nujabe
nujabe's Avatar
Is that what's pluged in to the bmc? I spilled a little fluid on it. Or any other ideas?
Old 01-20-2011, 11:54 AM   #4
besTint
Trader Rating: (81)
the brake master has a vacuum line that goes across to the intake manifold. make sure that plugged in and check that line for any leaks. the idle air control valve (iacv) gets dirty/clogged and causes idle to bog or die when braking or sometimes just in full stop at idle. might have just been coincedance that it happened after your brake upgrade. a little carb/choke cleaner will do the trick.
