![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
F/S: Carbing strut bar, drift freaq mounts, SR flywheel, and MORE stuff you need!
Carbing steel front strut tower bar
This is an authentic carbing one-piece steel front strut tower bar. It will work for an s-13 or s-14. The paint is chipped and scuffed here and there, but the bar is not dented or bent anywhere. Fitment is awesome! $100 ![]() UN-USED drift freaq urethane engine mounts (yellow) I'm getting the new mounts so I don't need these anymore. These are probably the best mounts out there. I had another set that I used for years without issue. They're true isolated mounts and do not significantly increase vibration. These are un-used, they have only been installed for mock-up. SOLD! Stock, MACHINED, RWD SR20 flywheel This is a stock OEM flywheel for a RWD SR20. It is freshly machined, ready to use... $50 ![]() Un-cracked S-13 coolant tank This is an OE nissan coolant tank in un-cracked, not leaking condition. It comes with the plastic cap and the hose. $25 ![]() 12" electric fan I'm not sure of the brand, but it is in good working condition. I do not have any of the mounting hardware though, you would need to buy a mounting kit. $20 ![]() S-13 KA starter It's pretty dirty, but it is in good, working condition. The pigtail with the connector is missing though, you would have to wire yours up to it... $20 ![]() S-13 SOHC KA belts I have a full set of barely used, good condition, s-13 KAE accessory drive belts. All 3 belts are included and I will not separate them... $10 ![]() S-13 SOHC alternator It's pretty dirty, but it is in good, working condition. It is originally from a SOHC KA, but I think you can use it on a KADE if you swap the pulleys. $20 ![]() S-13 SOHC ignition coil/bracket This coil is in good working condition and is originally from a SOHC KA. It can be used on a KADE, but you have to lengthen the connector a little to reach... $10 ![]() S-14 SR lower harness This is a complete, un-damaged S-14 SR lower trans. harness. All connectors are in good shape and nothing is cut. $40 ![]() S-13 SR20DET coilpack harness The harness is in great shape, no damage. $25 ![]() Last edited by racepar1; 02-01-2011 at 10:34 AM.. |
