Old 03-22-2011, 01:11 PM   #1
jetpower
jetpower is an unknown quantity at this point
RB25DET S2 Complete Engine except the Transmission
What I have up for sale is an RB25DET S2 engine that's complete stock. Since it's my daily, the motor is still in my S13 so you're more than welcome to come check it out.
Cons:
The motor still runs strong however, I fried the ECU just the other day. I soldered where it was burned on the board and it seems to be running fine. Another thing is that it has an oil leak from the front belt cover, wiring seems messy.
Pros:
Never overheated, good turbo with very minimal shaft play, new timing belt, LS2 truck coil conversion (I still have the stock ones too as well if you want them), good compression, new NGK plugs.
I will include EVERYTHING but the transmission, and the clutch assebly, I will leave the flywheel on. The only thing it does not have is the AC compressor. The reason why I am selling the motor only is because I am upgrading to RB26 this summer. I am asking $1000 firm. I do have a truck so I am willing to deliver as long as you compensate for the gas. Remeber, there aren't many deals where you get to test the motor on the road before you buy it. If you have any questions, call me at (210)415-5781 and we will work out a deal.
The pic below is the one I took when I was doing the LS2 coil conversion. I will take more pics when I get home later. Thanks
jetpower is offline   Reply With Quote
