Old 10-04-2003, 05:04 PM   #1
LowBattery
LowBattery's Avatar
LowBattery is an unknown quantity at this point
Clicking noise
Recently, I've been noticing a clicking noise coming from the rear of my car when I drive. The sound only lasts a second or two, and I only hear it when I start moving from a stop or a low speed (1st or 2nd gear); just 2-3 clicks before I start moving again. From the driver's seat it sounds like it's coming from underneath the car, somewhere between the passenger seat and the rear seat. I thought it had something to do with my differential, but I took it to a shop and they said nothing was wrong. So I was just wondering if anyone has experienced anything similar and could tell me what's wrong. Thanks in advance.
My car is a 95 SE with ABS and an LSD.
LowBattery is offline   Reply With Quote
Old 10-04-2003, 07:30 PM   #2
kanekz
kanekz's Avatar
kanekz is an unknown quantity at this point
It could very well possibly be your LSD!! You have a mechanical LSD correct? Most LSD will have click/thumping sounds and you just got to live with it.
kanekz is offline   Reply With Quote
Old 10-04-2003, 07:45 PM   #3
LowBattery
LowBattery's Avatar
Thanks for the reply. So there's nothing wrong? Would changing the differential oil help make the clicking less noticable? I haven't changed mine for over 10k miles.
Old 10-04-2003, 07:55 PM   #4
kanekz
kanekz's Avatar
As far as chaging intervals. Everyone has their own preference depending on the type of driving they do including track/drift events. Some do every 8K..just depends. As far as clicking supression, I think it was Driftingpanda who added some type of additive to supress the clicking. IMO, just change the diff oil and live with the clicking.
Old 10-05-2003, 01:16 PM   #5
LowBattery
LowBattery's Avatar
But would a louder clicking noise mean that something is wrong with the LSD? I don't remember hearing such loud clicks before, and my car has always had an LSD.
Old 10-05-2003, 07:50 PM   #6
rednerd
rednerd is an unknown quantity at this point
Unless you have an after market lsd, it is fine. People who complain about lsd noise are refering to conventional lsd clutch chatter.
Check your bushings (the bolts should be centered in the rubber) and ball joings in the back.
rednerd is offline   Reply With Quote
Old 10-05-2003, 11:46 PM   #7
holisticbeatz
holisticbeatz's Avatar
holisticbeatz is a well-known jackass
Re: Clicking noise
What kind of a LSD do you have?
Trust and I don't mean GReddy.
holisticbeatz is offline   Reply With Quote
Old 10-06-2003, 12:00 AM   #8
LowBattery
LowBattery's Avatar
I have the stock VLSD. I think I'll just change my differential oil and add some LSD additive and see if it'll quiet things down. If not, since everyone's telling me the clicks are normal, I won't worry too much about it.
Old 10-07-2003, 07:52 PM   #9
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
s13
Did you try the CV joints?
240silvia is offline   Reply With Quote
Old 10-08-2003, 09:41 PM   #10
LowBattery
LowBattery's Avatar
Haha... what is a CV joint? And would a bad one also cause this problem?
Old 10-08-2003, 10:25 PM   #11
nismofeind
nismofeind is an unknown quantity at this point
if you have exhaust check to see if the exhaust is hitting the rear inner bolt on your drivers side seat mount. or if its close.
nismofeind is offline   Reply With Quote
Old 10-09-2003, 01:32 AM   #12
240silvia
240silvia's Avatar
Sudden CV joint failures are rare, but the joints do wear out and can fail as a result of loss of lubrication or grease contamination (usually due to a failed boot). A CV joint that’s failing usually produces various symptoms:
A popping or clicking noise when turning. This almost always indicates a worn or damaged outer CV joint. A quick way to verify this condition is to put the car in reverse, crank the steering wheel to one side and drive the vehicle backwards in a circle (check the rearview mirror first!). If the noise gets louder, it confirms the diagnosis and the need for a new joint or replacement shaft assembly.
Is that basic enough for you???
Old 10-09-2003, 09:21 AM   #13
LowBattery
LowBattery's Avatar
Yes it is, thank you I just tried the test and the clicking noise doesn't happen when I turn, so I'm still thinking it's the LSD. I just need to change the differential oil, but I'm having trouble finding the addtive that'll to make it quieter.
Old 10-09-2003, 02:47 PM   #14
240silvia
240silvia's Avatar
s13
It does sound like it's the LSD. I didn't mean to be an with my last comment. I thought you were trying to say there was no such thing as a CV joint.
Old 10-12-2003, 01:25 PM   #15
LowBattery
LowBattery's Avatar
I dug up this post on another board, and even though it refers to a G35, his symptoms sound a lot like mine. So it is likely that I have the same problem as the G35 owner or does it still sound like an LSD problem? I'm hoping it's the latter since the other one sound expensive
