Old 10-12-2003, 02:04 PM   #1
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
installed boost gauge but...
ok there is only one line running vacuum, and when i have it hooked up, its usually on 20psi vacuum, it only goes into boost when im on the gas, if im barely on the gas its still in vacuum, it goes up to like 11psi too when i gas it all the way...is this normal for a boost gauge, i would have thought that as long as the turbo is spooled up it would show boost...?
89 240 SR powered...
ummm i promise its stock
TheSparo is offline   Reply With Quote
Old 10-12-2003, 02:12 PM   #2
Titan
Titan is an unknown quantity at this point
Yes, this is normal. The turbo won't produce boost unless there is load applied.
You have your vacuum line T-ed off at the the TB right? Well, when you let off the gas, the throttle plate closes, creating a vaccum through the intake manifold. This causes your gauge to display vaccum.
Sleep Doesn't Drink Beer
Titan is offline   Reply With Quote
Old 10-12-2003, 07:11 PM   #3
srJOEYdet
srJOEYdet's Avatar
srJOEYdet is an unknown quantity at this point
Mine does that.
Joey
Exceed 400x200 size limit
srJOEYdet is offline   Reply With Quote
Old 10-12-2003, 07:58 PM   #4
TheSparo
thank ya much all
