Old 04-27-2011, 10:25 PM   #1
JDM_PILOT
JDM_PILOT is an unknown quantity at this point
Ka24e no start/no crank help plz!!!!
hey whats up. i had a 89 hatch (ka24e). it overheated and i put a new head gasket. an after wireing evrything back uup. it wont start or crank. the dash lights dont even come on. i checked the fuses. and evn replaced a 15 amp fuse under the hood in the fuse box. i really need my car running asap this is my daily. the battery is good to yes. point me in a direction please taking all sujestions. thanks
JDM_PILOT is offline   Reply With Quote
Old 04-27-2011, 11:41 PM   #2
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
Check all of your harness connections and grounds. Also make sure the alternator is hooked up completely. There are 3 connections for it. Make sure you battery is fully charged.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 04-27-2011, 11:56 PM   #3
Hb180sx
Hb180sx is an unknown quantity at this point
what he said^^^^ i had the same issue, lights wouldn't turn on, turned out to be loose grounds double check every connector and clean the area where your grounds are hooked to. Good luck
Hb180sx is offline   Reply With Quote
Old 04-28-2011, 09:58 AM   #4
JDM_PILOT
ok i will thanks guys. im going out there now to give it another shot. like i literally checkd over all my grounds an fuses liek 100 times! :/. but ya obviously ive missed something
Old 05-03-2011, 10:57 PM   #5
oats91
oats91's Avatar
oats91 is an unknown quantity at this point
Check your fuses under steering column on the left side
oats91 is offline   Reply With Quote
