![]() Got home work today and noticed that fuel is leaking from the bottom of the vapor canister, is this thing junk? Looks like return line back to the tank runs through the canister? Any answers or ideas
![]() Join Date: Jan 2011
Trader Rating: (43)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 43 reviews
You top off your gas tank when you refill? Thats the only reason I can think of that your charcoal canister would be full and spilling it out.
And it's not a return line, it's basically like a breather for your gas tank, it can be deleted with a plug and a clamp on top of the gas tank. |
I pulled the 3 hose coming off of the canister, 1 vacuum, 1 line back to tank, on bigger
Hose there was gas coming out of that line. It had some pressure behind it but not a lot. |
Never had a problem before when filling my gas tank, until now. I placed a bottle to collect the fuel come from the line off of canister and as soon as I pulled fuel cap off and relieved pressure the fuel from line stopped. Where is the tank vented, maybe the vent is stuck closed
Trader Rating: (43)
It vents fumes through canister.
Personally I think your tank is just overfilled. Don't top off when you fill up, just until the pump clicks off. Topping off causes the charcoal canister to saturate and leak out. |
![]() Update:
Still haveing the same problem, haven't topped off tank since. Even at 3/4 of tank and its above 80 degrees I get raw fuel pushed through vent line and out of charcoal canister. |
![]() Update:
#15 |
you ever solve the problem. my car started doing the same thing today. i dont have the canister and i have a sr, so my gas tank breather is just ends and is open by the starter and the rest of the fuel lines. never did this till today.
