Old 06-23-2011, 07:19 PM   #1
RBMadess
RBMadess is an unknown quantity at this point
Arrow s14 obd1 or obd2 abs or non abs 100% complete 5 speed conversion
Totally complete! Every part, even nuts and bolts! With centerforce clutch, new master and slave. Genuine s14 clutch pedal.
1k picked up or $1400 installed professionally by my buddy at his shop.
- Low milage S14 5 speed manual transmission, NO grinds, NO leaks. All sensors and. plugs in great condition, includes shifter, fork and throw out bearing in good condition.
- S14 Speed sensor (s13 one will NOT work)
- S14 Crank angle sensor (on transmission bell housing, no cracks, heat shield intact)
- S14 OBDI manual ECU (will include if you have your working auto ecu core)
- S14 transmission dust plate (metal plate between engine and transmission bell housing)
- S14 manual drive shaft, center bearing in great condition
- S14 lower harness, (no cracked or cut plugs)
- Low milage centerforce pressure plate and clutch plate (90% left on clutch)
- Great condition flywheel, no warping or grooving, no chipped teeth.
- S14 clutch pedal (s13 ones don't have the rear bolt spacers)
- S14 brake pedal
- S14 clutch hard line
- S14 NEW master and slave clutch cylinder
- S14 NEW pilot bushing
- S14 lower boot with metal bracket
- S14 shifter trim with oem shift boot and shift knob
- Will include all bolts and nuts, I'll even throw in synthetic clutch fluid.
If interested please call or text 714 483 8563
RBMadess is offline   Reply With Quote
Old 06-23-2011, 07:23 PM   #2
roushman90
roushman90's Avatar
roushman90 is an unknown quantity at this point
Bump, someone needs this.
roushman90 is offline   Reply With Quote
Old 06-24-2011, 11:23 AM   #3
RBMadess
i agree! convert your autotragic and have more fun in your 240!!!
Old 06-25-2011, 11:01 AM   #4
RBMadess
sold! mods please close, thank you.
