Old 07-01-2011, 02:11 AM   #1
muffler
muffler's Avatar
muffler is an unknown quantity at this point
cant bolt transmisson to motor-gap
there is about a half an inch of gap between my motor and transmission what am i doing wrong? clutch alignment tool slides in fine, is it possible my pilot bushing isnt pushed in far enough to cause that gap?
muffler is offline   Reply With Quote
Old 07-01-2011, 02:14 AM   #2
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Splines prob aren't aligned.
SLiDe_WaYz is offline   Reply With Quote
Old 07-01-2011, 02:16 AM   #3
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
You have to kinda rotate/clock the trans into place... it helps if your engine is tilted back some. Get a friend or two to help.
Is this an auto to manual swap?
az_240 is offline   Reply With Quote
Old 07-01-2011, 02:24 AM   #4
muffler
muffler's Avatar
yeah the motor was off an auto because mine was toast, but if the splines arent aligned wouldn't it have gotten stuck at the very begging? its getting stuck like right before its about to touch the engine
Old 07-01-2011, 09:05 AM   #5
Sileighty_85
Sileighty_85's Avatar
dowel pins are not lined up
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-01-2011, 09:09 AM   #6
jr_ss
You have to remove something from the back of the auto crank before you attempt to put the manual trans in. There's a bushing or something that the manual engines don't have but the autos do for the torque converter.
Old 07-01-2011, 09:30 AM   #7
SLiDe_WaYz
SLiDe_WaYz's Avatar
This make sure you remove the auto pilot bushing and install the manual one other wise your going to have to drop the engine and trans again and swap them out. I found that out the hard way. It blows. Big time.
Old 07-01-2011, 02:42 PM   #8
muffler
muffler's Avatar
the auto bushing was replaced, heres how big the gap is..it slides in fine untill this point.. do i push harder?
Old 07-01-2011, 02:46 PM   #9
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
wiggle the tranny and push in harder at the same time and tilting the motor helps even more by loosening up the motor mounts and take the upper radiator hose off.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 07-01-2011, 10:21 PM   #10
roushman90
roushman90's Avatar
roushman90 is an unknown quantity at this point
+ 1
roushman90 is offline   Reply With Quote
Old 07-01-2011, 03:58 PM   #11
Sileighty_85
Had a customers car do this once.
The Splines on the clutch plate got a little mushroomed and had to file them a little.
take off the clutch disk and see if it will slide on to the input shaft
後輪駆動車1番
1986 SR86 - 200ish
Old 07-01-2011, 04:22 PM   #12
SoCalDrifter
SoCalDrifter's Avatar
SoCalDrifter is an unknown quantity at this point
that happened to me i just took plyers and just pulled it together
SoCalDrifter is offline   Reply With Quote
Old 07-01-2011, 04:29 PM   #13
RyanS13
RyanS13's Avatar
RyanS13 is an unknown quantity at this point
It'll go together. It might not seem like it but it will. My car did this same thing everytime I've dropped the trans. Reach your fingers in the back of the trans where the drive shaft goes in at, and twist it while you wiggle the trans back and forth and push it in. Helps if you have another guy in the front tilting the motor. Also you could get a piece of wood and hit the back of the trans in, that's what I had to do once. Mine never just slid in easy.
RyanS13 is offline   Reply With Quote
Old 07-01-2011, 05:10 PM   #14
jr_ss
I'd refrain from trying to force it in. You can and will bend your clutch disk. Back it off some, spin the input shaft and try restabbing it. If you have too, put the trans in gear and turn it clockwise/counter clockwise to aid in lining the splines up. Use some force but don't just say fuck it and squeeze it together with the trans bolts. I suspect youre not splined correctly.
Old 07-01-2011, 05:17 PM   #15
airhead
airhead's Avatar
Trader Rating: (32)
airhead is making a name for him/her selfairhead is making a name for him/her selfairhead is making a name for him/her self
Feedback Score: 32 reviews
looks like a two player job
airhead is offline   Reply With Quote
Old 07-02-2011, 12:12 AM   #16
chetos13
chetos13's Avatar
chetos13 is an unknown quantity at this point
Send a message via Yahoo to chetos13
how did u install the pilot bearing u may have bent the pilot bearing. grind it the inside of it but not to much. remove the clutch and flywheel so u dont get any metal shavings
TEAM ELITE
chetos13 is offline   Reply With Quote
Old 07-02-2011, 04:09 AM   #17
SLiDe_WaYz
SLiDe_WaYz's Avatar
This, to can get a file at any parts store there like 2-3 bucks. I'm not looking forward to taking mine apart and putting it back together again just bc of this right here.
Old 07-02-2011, 01:57 PM   #18
260sexways
260sexways is an unknown quantity at this point
Like everyone said its an allignment problem or if you had an automatic the torque converter isn't fully seated
260sexways is offline   Reply With Quote
Old 07-02-2011, 02:58 PM   #19
n8RPS13
n8RPS13's Avatar
Trader Rating: (22)
n8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of light
Feedback Score: 22 reviews
To get the engine to tilt back you can also put a jack under the oil pan with a piece of wood between them to protect the pan, lossen the motor mounts, and then jack the motor up until the back of it it hits the firewall
WASTED I AM!
n8RPS13 is offline   Reply With Quote
Old 07-02-2011, 03:08 PM   #20
SLiDe_WaYz
SLiDe_WaYz's Avatar
That won't work if he's having alignment problems. File down the teeth on the clutch disk and see if it will slide onto the input shaft afterwards.
Old 07-02-2011, 03:51 PM   #21
muffler
muffler's Avatar
its in i just got a c clamp and it just slid in
Old 07-04-2011, 07:05 AM   #22
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
nevermind, solved lol
Tantwoforty is offline   Reply With Quote
Old 07-04-2011, 07:25 AM   #23
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
Should've put bolts on and started tightening them
SW Fab
shiftdrift is offline   Reply With Quote
Old 07-04-2011, 07:46 AM   #24
Tantwoforty
^thats what i said in my post..
i just had to do that haha
Old 07-07-2011, 01:05 AM   #25
muffler
muffler's Avatar
yeah thats what i did once the c-clamp made the threads close enough, thanks guys
Old 07-12-2011, 05:59 AM   #26
zeebrah
zeebrah is an unknown quantity at this point
haha i read this the day after figuring this out on my own >:/ but yes the combo of c clamps and longer bolts did the trick.
zeebrah is offline   Reply With Quote
