Old 08-08-2011, 08:09 PM   #1
sl87
sl87 is an unknown quantity at this point
Oil in intake manifold
I have ISIS intake manifold. Question:
Does this port behind my intake manifold:
hook up to this port on my valve cover?:
Could this be the reason there is oil in my intake manifold? Doesn't seem like there is a lot. The only reason i say that, is because i unscrewed one of the vacuum plugs underneath the manifold and the bolt had a layer of oil. Thanks
sl87 is offline   Reply With Quote
Old 08-08-2011, 08:34 PM   #2
c-los13
c-los13's Avatar
c-los13 is an unknown quantity at this point
why hasnt anybody reply to this????????????/
DUDE STOP WHAT YOU DOING NOW!!!!!!!!!!!!!!!!!!!!!!!
im pretty sure the port on the mani is for the brake booster, the one on the valve cover on the manifold as well, there is gotta be a write up on this, search before you keep driving your car
gl
c-los13 is offline   Reply With Quote
Old 08-08-2011, 08:44 PM   #3
Sileighty_85
Sileighty_85's Avatar
if you actually look at the pic you can see that that hose does not go to that port you can see that it goes along the fire wall.
Its common for oil to build up in the bottom of the IM i think a solution is to install a mini Oil catch can for the PCV valve system
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-08-2011, 11:01 PM   #4
sl87
Behind my intake manifold, there are two ports. One port is connected to the brake booster and one port is connected to my valve cover. When i changed out my intake manifold, i connected the lines like the stock manifold. So that port on my valve cover is supposed to connect to the port behind my intake manifold? I've seen some people put a mini filter there. Is that the proper thing to do?
Old 08-09-2011, 12:42 AM   #5
sl87
I've never seen some one run a catch can on that port and on the t valve on the exhaust side. Although it would make sense, i guess i could put a check valve there. I have a map sensor, boost gauge, and fpr connected to my vacuum sources on my
ISIS manifold and dont want oil in the vacuum hoses, which i found. A mini catch can would be interesting on that port. Anyone done it before??
Old 08-09-2011, 08:15 AM   #6
bb4_96
bb4_96 is an unknown quantity at this point
if you dont want oil in the im you need to research proper catch can/blowby/vc mods. This forum has badass amounts of independent r&d if you're willing to look. If not I'll sell you the links.
bb4_96 is offline   Reply With Quote
Old 08-09-2011, 04:17 PM   #7
sl87
I've been researching about blow by and anything related to it. Did not realize there was so much on this subject. I retract my questions on this thread, i have gained the knowledge to know what to do now. Hopefully...lol
Old 08-09-2011, 09:09 PM   #8
bb4_96
atta boy!!
Old 08-09-2011, 04:31 PM   #9
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
seriously dude
