Old 08-30-2011, 06:53 PM   #1
240sxspeed
240sxspeed's Avatar
240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold
Exclamation sr20det built block and head for sale
I have for sale a sr block for sale it has cp pistons and eagle h beam rods in it . I had a set of bc cams in the build and one of the cams broke at low speed and rpm causing the valvetrain to fall in the block there was very very minor damage to the block small nicks on the pistons non inside the cylnder walls at all although i would recommend changing the number one piston just because the damage is close to the edge of the piston but the bearings are fine the motor spins freely . The motor had about 500 miles on it when the cams broke the cross hatch from the hone is still visible . Also i have a blank blacktop head for sale it still has hydralic lifters and cam caps and bolts in place i am asking 200 for both yes for both i am going 2jz so this block and head just became a really big pair of paper weights call text me for faster responce 6096682594 thanx for looking
HOME OF THE LOWBALLERS AND INTERNET THUGZ
240sxspeed is offline   Reply With Quote
240sxspeed
