Old 09-03-2011, 09:32 AM   #1
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Talking CA Wire gurus i need some help
- 93 ka
- 5 speed
Car ran great. i started her right up, as normal. I parked for 8 hours, the i try to turn the car on, and BAM one click and everything in my car just died. no power to anything clock went out, so i know my "battery" died. Took it out, thinking i had left my fogs on, and re-charged my battery, tested it, it was good. returned to my car, install the battery, and it did it again. disconnect the battery for a few minutes reconnect it , I GET ALL MY POWER BACK, LIGHT WORKS CLOCK WORKS, EVERYTHING, but as soon as i try to start it, BAM ONE CLICK and the car loses everything again ??
S-Nation S13 is offline   Reply With Quote
Old 09-03-2011, 09:42 AM   #2
shaggy sr
shaggy sr's Avatar
shaggy sr is an unknown quantity at this point
time for u to sell the car. parting it out? lmk!
shaggy sr is offline   Reply With Quote
Old 09-03-2011, 09:52 AM   #3
S-Nation S13
Trader Rating: (92)
nope !! are you serious .. lol 2011 join date .. get the fuck out of here if your not going to help the situation !!
Old 09-03-2011, 11:21 AM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
honestly it sounds like a poor connection either at the battery or your main ground wire from the battery to the chassis.
Old 09-03-2011, 11:48 AM   #5
Jake1992
Jake1992's Avatar
Jake1992 is an unknown quantity at this point
when ur car draws alot of current it turns off.. like someone allready said check ur main ground on the engine... the pole's on the battery ... positive lead...theres a connection loose somewhere...
Jake1992 is offline   Reply With Quote
Old 09-03-2011, 11:59 AM   #6
Banegraphix
Banegraphix's Avatar
Banegraphix is an unknown quantity at this point
had the same issue in a old track car turned out to be my battery terminal clamps, got a new set and never did it again
Banegraphix is offline   Reply With Quote
Old 09-03-2011, 01:24 PM   #7
WESamiss
WESamiss's Avatar
WESamiss is an unknown quantity at this point
Agreed.
I had this same exact problem dude. It turned out to be a bad connection for a battery terminal.
-WES
WESamiss is offline   Reply With Quote
Old 09-03-2011, 01:13 PM   #8
davirene
davirene's Avatar
davirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nice
Its the smaller wire connected to the battery terminal....it has corrosion inside....clean it....
I had the same exact problem...
davirene is offline   Reply With Quote
Old 09-03-2011, 07:20 PM   #9
S-Nation S13
Trader Rating: (92)
Cool I just got back to my comp.. I forgot to mention ... LIKE A NOOB my battery in located in my trunk .. and the small wires connected to my + terminal are all bundled together in the front
Old 09-03-2011, 07:47 PM   #10
silva.240
silva.240 is an unknown quantity at this point
definately bad grounds!!!! its easier to put a new wire between the battery and motor and another for the battery to chasis and remove that old corroded wire out the way
silva.240 is offline   Reply With Quote
Old 09-03-2011, 09:16 PM   #11
S-Nation S13
Trader Rating: (92)
thank you to all that have helped another fellow zilvian member.. PROBLEM SOLVE.. LOOSE CONNECTION .. ON THE POSITIVE SIDE OF MY BATTERY NOT TO THE POST CONNECTOR BUT THE DAMN CONNECTOR THAT HOLDS THE WIRE TO THE TERMINAL CONNECTION !!!!
THANKS AGAIN !!!!
electrical, s13, s14, start, wires
