Old 09-19-2011, 11:05 PM   #1
Nibras
Nibras's Avatar
Nibras is an unknown quantity at this point
Send a message via AIM to Nibras
s14 Ca18det Overheating ....blown headgasket? LMK your opinon!
alright so i have a ca18det that has recetly started to overheat .
The car will idle and then about 5 minutes the temp gauge jump from halfway and creep up past the overheating line . it busted a radiator hose so i changed the hose the car overheated 5 mins again.
the thermostat was removed before i owned the engine and kept it that way.
i have a gt28 turbo , stock injectors , godspeed raidiator ,
i had to drive the car home as the temp gauge pinged.
do you think its possibly blown headgasket.
i am going to be doing a compression test and then a leakdown test .
Anyones input will be great.
thanks
Nibras is offline   Reply With Quote
Old 09-19-2011, 11:07 PM   #2
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
do you have the radiator hoses hooked up backwards?
TLDR
Cliff notes: Florida
sr20sean is offline   Reply With Quote
Old 09-19-2011, 11:15 PM   #3
Nibras
Nibras's Avatar
The car has been running for about 4 monthes with that motor , the only known problem i had was a odd noise from the timing case i figured the tensioners.
Old 09-22-2011, 02:45 AM   #4
iveexcaped3
iveexcaped3's Avatar
iveexcaped3 is an unknown quantity at this point
Seems like maybe your water pump isn't circulating the fluid so it just sits and runs hot. Check the oil is it milky check the coolant does it have oil. Does it start?
iveexcaped3 is offline   Reply With Quote
Old 09-22-2011, 02:48 AM   #5
iveexcaped3
Also maybe some thing to think about my friends civic started to over heat and couldn't find out why. Final result was her intercooler was blocking most of the air flow to the radiator so I couldn't breath
Old 09-22-2011, 03:28 AM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Did you bleed the cooling system properly?
CLICK HERE!!!
Old 09-24-2011, 06:55 PM   #7
Nibras
Nibras's Avatar
yea i bled it and it has stopped overheating to the TOP line but its still running a bit hot now
there was somekinda plastic clogging my intercooler and oil built up in but i cleared that out , and the car does run
ca18det, ka24de, motor, overheat, sr20det
