![]() Join Date: Jul 2005
Trader Rating: (145)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 145 reviews
![]() Check out my Feedback or Trader Rating
Located in Garden Grove, CA. 92843. Email - [email protected] Call/Text - 657-377-8I30 Price does NOT include shipping and shipping is not free. Please add 3% for PayPal or send as gift. NO trades b/c CASH is KING. I delete ALL sold parts within 24 hours so if you see it here, its available. * For instant respond, reply to this thread since it will forward to my cell. UPDATED on 5/10/22. All parts and photos are listed on page one. My other thread: NEW parts listed ![]() S13 radiator bushings: top sold bottom $10 2x, last 2 ![]() S13 steering rack brackets - $15 2x ![]() S13 fuse cover - $5 ![]() S13 top hats with hardware as shown - $30 ![]() S13 Silvia headlights caps/locks - $10 2x ![]() S13 temperature sensors - $20 ![]() S13 dohc throttle cable bracket - $5 ![]() S13 oil cap - $5 -yellow cap sold ![]() S13 fuel filter bracket - $10 ![]() S13 timing tensioner - $20 S13 timing guard - $20 ![]() male lighter - $5 ![]() S13 chassis rubber plugs - $2 each ![]() S13 vacuum (connects to brake booster) - $5 each S13 donut lock bolt - $5 each ![]() Differential or transmission plug - $10 each ![]() S13 SR transmission sensor - make offer ![]() S13 radiator bracket - sold S13 SR throttle body bracket - sold
i have engine hoist for rent i do SR wiring Last edited by vutony; 12-08-2022 at 10:40 PM.. |
KA auto flywheel bolts (3) - $10
- bolts are in good shape, not stripped ![]() ![]() S13 Rear Toe Arm Hardware - $20 ![]() Need other hardware, PM me. ![]() I have most hardware for S13 rear end as well. Axles bolts (complete set) - $40 shipped Driveshaft bolts (4) - $20 shipped Diff bolts to subframe (2) - $15 shipped Diff cover bolts (8) - 20 shipped Diff fill 1/2" ratchet bolt (1) - $10 shipped Diff drain - SOLD Tomei diff gasket - $20 shipped (used but very little miles and looks new) S13 diff cover - SOLD ![]() brake reservoir tank - $10 ![]() axle hardware - $10 ![]() sway bar endlinks - $10 per set (one set sold, two left) ![]() subframe bracket - $10 per set, 2 ![]() s13 door openers - $15 both ![]() S13 steering column - $40 top column - Removed from running cars - In good shape, threads are intact ![]()
i have engine hoist for rent i do SR wiring Last edited by vutony; 12-08-2022 at 10:44 PM.. |
s13 rear caliper bolts - $10
![]() engine cross member hardware - $10 per set, one set sold ![]() wheel stopper - $10 ![]()
i have engine hoist for rent i do SR wiring Last edited by vutony; 12-08-2022 at 10:46 PM.. |
#7 | |
![]() Join Date: Jun 2008
Cluster Cover
Hi! Do you still have these available? Thank you |
Stock SR Parts
Transmission mount to transmission bolts - $5 Transmission bracket to chassis bolts - $10 ![]() SR20 5 speed flywheel bolts (8) - $30 - bolts are in good shape, not stripped - Six 6PT bolts and two 12PT bolts ![]() Nismo radiator cap - $20 ($55 @ frsport.com) ![]() OEM SR headstuds - $40 - In excellent shape - Has about 5,000 miles on them ![]() ![]() SR20 Turbo Oil Return Tube - $20 ![]() SR20 5 speed flywheel bolts (8) - $30 - bolts are in good shape, not stripped - Six 6PT bolts and two 12PT bolts ![]() SR20DET coolant sensors - $20 Pipe and hose - $sold ![]() Crank pulley bolt and washer - $10 ![]() S13 SR injector caps, cushion ring spacers and bolts - $30 each set of 4
i have engine hoist for rent i do SR wiring Last edited by vutony; 12-08-2022 at 10:48 PM.. |
Stock S14 Z32 Z33 Q45 Parts
S14 Auto Driveshaft - $80 - Removed from a running car - Center carrier is good shape ![]() ![]() ![]() S14 Ebrake cables - $30 - Removed from a running car - Cables are in good shape ![]() 350Z G35 Brembo Slotted Rotors Front Set $220 (Purchased new at FR @ $389.95 plus tax) - In great shape with less than 2,000 miles. - Has a minor defect from the calipers rubbing on the rotors. - Its about 30.16mm thick, min thickness is 28.4. - Rotors are 12.75 in diameter Z32 Front conversion brackets to use 350Z rotors I can get these for you if needed $100 extra. The brackets below are sold. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Z32 rear caliper bolts - $10 shipped ![]() Q45 ignitor w/ pigtails - $30 i have the installation if needed ![]() ![]()
i have engine hoist for rent i do SR wiring Last edited by vutony; 12-08-2022 at 10:50 PM.. |
SOLD
Z32 OEM rear brake pads S13 SR ignitor pigtails S13 gas tank neck S13 coupe trunk assembly Raybestos front pads S13 center console S13/S14 rear 4 lug hubs S13 foward links (traction arms) w/ energy bushings pressed S13 toe arms w/ energy bushings pressed S14 rear traction arms S13 hood latch cable S13 oem powered mirrors s13 base model antenna s13 silvia triple projector housing Door shells (bare) rear support S13 steering column cover stereo amp "white box" T25/T28 OEM coolant line Oil line sohc and dohc throttle cable rear hatch speaker brackets
i have engine hoist for rent i do SR wiring Last edited by vutony; 12-08-2022 at 10:51 PM.. |
#13 | ||
PM'd
Sorry no. Thanks, done deal. PM'd
i have engine hoist for rent i do SR wiring |
#15 |
any chance you've got a lock cylinder for an s13 drivers door that works properly? send me a pm or text me 815 508 2202
WTB: 1/24 scale chuki s13 model. |
#20 | ||||
Yes for SR, http://zilvia.net/f/sale-items/40039...ngle-part.html
#21 |
![]() Join Date: Apr 2007
I feel like a dick asking, cause i hate when people ask for parts not listed, but do you have a S13 fuel pump hanger assembly?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo |
#22 |
![]() hey mate, just letting you know ive sent you an email from [email protected] regarding some parts
#23 |
![]() The following items sold to me:
S13 Gas Tank Neck DOHC digital cluster part – the black cover S13 side mouldings near window OEM S13/S14/S15 SR20DET O2 Sensor (FAT type) S13 SR ignitor pigtails only Thanks! ![]() |
#26 | |||
LMK
#30 | |||||
Sure if your willing to pay
THanks Quote:
Replied Yup thx
