Old 09-21-2011, 01:03 PM   #1
datsunmotorsports
datsunmotorsports is an unknown quantity at this point
RB Engine Parts and Datsun Triples
-stock RB25 wastegate actuator $40
-JDM Sport R33 Skyline FMIC. All the pipes are sold, sorry. Just the intercooler is left. (kit was $250 new) $90
-EMUSA cat-delete test pipe NEW $50
-Stock RB25 MAF P60 x2 $85 ea
-HKS turbo intake pipe & matching HKS BOV pipe rb25det should fit S13 or S14 well $75 obo
-Black RB25 Spark Plug Cover (one is S1 and one is S2 I think) $15
-APEXi Pen style Turbo Timer USED box and instructions. Im including the 3 pin harness connector for universal connection(which this unit does not come with out of the box new) $45
-RB20 or RB25 Exhaust Manifold Studs M10X1.25 48mm NEW NLA from Nissan 01151-00471 $1.70 ea
-Greddy "style" type S BOV. It was used for 2 hours and replaced with a Tial Unit. Asking $30 firm
-RB26DETT twin turbo exhaust manifolds(R34 manifolds with less than 18K miles on them) - $100 obo
-Customized intake manifold for a RB25DET. It uses the stock throttle body. I spent $200 on it so Id thought I would try to recoup my cash back rather than recycle this. Hopefully someone needs it. Locates the TB in a better spot for anyone installing an RB25 into a S30, S130, Z31, S13, or S14 Nissan Platforms. (Z or SX cars) I would like to get at least the machine work costs back out of it. If your thinking about having this done to yours then you can save yourself the time and a little extra cash by buying this one. $175.00 firm.
-throttle bodys with the S2 tps on it for $50ea
throttle body for S1 $50
-Stock RB25det Intake manifold. $75 obo
-RB25det engine mounts $50 pair obo
-RB25det mount isolators $25 pair obo
-Bits of OE intercooler piping and couplers $5-$40 ea
-RB20 or RB25 OE Turbo-Cat elbow and down pipe. 2.5" stock peices $60 obo
-3" High Flow OE Nissan Cat with 2 bolt flange on each side USED $100 obo
-RB25det stock exhaust manifold $80 obo
-RB25det stock cold pipe $15
-R33 HKS pipe for the intercooler $80
-RB25 S2 coil packs, condition iffy, but unknown $40 set of 6
-RB25det S2 ECU 23710-21U60 01/95-08/95 RB25DET MT F5 known good runner 80K miles $150
-RB25det S2 ECU 23710-21U60 01/95-08/95 RB25DET MT F5 known good runner ?miles $150
-rb25det OE fuel pressure regulator 81K miles $50
-rb25det boost contol valve x2 $25 ea
-32702-02G17 cable drive speedo 17tooth VSS eliminator $100 NIB
-A'PEXi 507-N006 ECR33/ER34/WGNC34/GC35/GCC35 RB25det and NEO6 Power Intake NIB $120
-rb25det exhaust elbow heat sheilds X3 $10 ea
-rb25det exhaust manifold heat sheild $10
-RB20 ECR32 valve cover and upper timing cover assembly $80
-RB20/RB25 upper rear timing cover plate $15
-RB20/RB25 oil sump pickup tube used $25
-RB20/RB25 dip stick tube $10
-R32/R33 USED Catalyst EGT sensor and pigtail $50
-248LPH in tank fuel pump $100
-RB30 S2 Turbo rods and pistons X5 $100
-N1 water pumps New in the box. part numbers 21010-24U27, yep real N1 pumps. asking $120 firm for each of them. I have a good supply of these for anyone interested. They run about $180-$190 elsewhere. Boxes are a little weathered, but pumps are sealed inside and in good shape!
-RB25det Exhaust Cam Shaft in good shape $100
-RB25DET new aftermarket head gasket $50
-OE New Exhaust gasket (rear most part of the gasket broke, but its still usable)$20
-Intake Upper Used $10, Lower intake used $10, lower intake aftermarket new $15, and used TB gasket $10
-HKS Turbo Timer USED with instructions $50
-Datsun L series 6 cylinder I have 3 Solex Mikuni PPH 40 carbs on a Mikuni Intake manifold with linkage and K&N filters. Carbs have been jetted for a mostly stock L28 Datsun engine. All three carbs have been gone through and many of the jets, air correctors, and nozzles have been replaced which wasnt cheap about 6 months ago. These came off a running L28 at end of July this year! 12mm booster, 37mm venturi, main jets 160, main air jet 200, pilot jets 62.5, choke/starter jet 130, accel pump nozzle 40. Mikuni manifold is un molested. It has about 2 hours of run time on it TOTAL! Ultra Rare intake. Sorry I will not sell just the intake by itself. The carbs are getting hard to find parts for and even the carbs are getting harder to find. The carbs are older second gen Mikuni carbs with unknown mileage on them, but they are in very good shape as they have been gone through. This setup will also have a set of K&N air cleaners. These are the tall oval K&N filters with chrome K&N housings. I also have a heat shield that was custom made for the header I have. Its not the prettiest, but it worked extremely well to cover the accelerator pumps and kept the engine bay temps way down. I am also including the linkage. The linkage I have is not the original Mikuni manifold linkage to the firewall. Its home made, but works. $1200
Trades? Feel free to make other offers Ill at least consider them. I will say I prefer cash though. I spent a lot of money on this stuff so try not to low ball. I would be interested in a power steering pump with lines, bracket, and reservoir for an rb25. I seem to have misplaced mine.
Pickup preferred, Shipping isnt easy for me, but I will work with you if thats the only option. Location: Prunedale aka North Salinas Ca 93907
831 402 5387
Ray
Last edited by datsunmotorsports; 09-23-2011 at 10:21 PM.. Reason: forgot to add price for mikunis
datsunmotorsports is offline
Old 09-23-2011, 12:29 PM   #2
90greys13
90greys13 is an unknown quantity at this point
do u have rb20 rod conectors
90greys13 is offline
Old 09-23-2011, 04:19 PM   #3
datsunmotorsports
Sorry I do not
Old 09-23-2011, 10:19 PM   #4
Bushido
Bushido's Avatar
how much are you looking to get for those mikunis?
Bushido is offline
Old 09-23-2011, 10:23 PM   #5
datsunmotorsports
Sorry, I fixed that. $1200 as the package, but Id be very willing to keep the manifold and just sell the carbs. The manifold was $600 by itself.
N1 Water Pumps are selling like hot cakes on ebay.
Ray
Old 09-24-2011, 01:32 PM   #6
racerx2k1
460
racerx2k1's Avatar
http://zilvia.net/advertise.html
Originally Posted by West
No Commercial Selling, if your selling commercial Group Buy then please contact Mark or Bob at [email protected] for advertising information and learn about our Advertising/Group Buys options.
racerx2k1 is offline
