Old 10-14-2011, 03:43 PM   #1
Josh7X
Josh7X's Avatar
Josh7X is an unknown quantity at this point
Thumbs down Another my 240sx won't start thread
Okay so my 1989 240sx won't start and I can't figure out why. The battery is fine and all the lights work. When I go to start it and turn the key all it does is click below the air cleaner at the fuse box. I don't understand why it won't start. The fuses are fine and so is the starter. This is my only car, so I need to fix it as soon as possible. Any help would be appreciated thanks.
Josh7X is offline   Reply With Quote
Old 10-15-2011, 12:54 PM   #2
Josh7X
Josh7X's Avatar
Anybody?
Old 10-15-2011, 01:01 PM   #3
Phlip
Yes, I look like that
Phlip's Avatar
Are you SURE the starter is good?
Also, how old is the positive battery cable?
reason I ask is because back in ancient times (2002), my positive cable was corroded on my S14 and it just didn't carry enough juice to the starter.
Weirdo
And I write too!
Old 10-15-2011, 01:44 PM   #4
bigrobg21
bigrobg21 is an unknown quantity at this point
check your ignition. happen to me once. it would turn all the guages on but wouldnt turn the car over cause it kept slippin. worth a shot.
bigrobg21 is offline   Reply With Quote
Old 10-15-2011, 02:00 PM   #5
memphis180sx
memphis180sx is an unknown quantity at this point
check your starter signal wire mine came off and did the same thing i was serching for 22 hrs tring to figure it out
memphis180sx is offline   Reply With Quote
Old 10-16-2011, 01:46 PM   #6
bchommmes
bchommmes is an unknown quantity at this point
this^^^
also try to jump your starter to make sure that the flywheel engages eliminating a bad starter
check the signal wire
clean up battery terminals
try in that order and let us know what happens
bchommmes is offline   Reply With Quote
Old 10-15-2011, 03:01 PM   #7
ultimateirving
ultimateirving's Avatar
ur batter leads are dirty/loose, clean them tighten them and report back.
Z32 with lq4 swap
Old 10-16-2011, 11:41 AM   #8
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
make you sure you have proper voltage coming from the battery to get the starter to work. or possibly your starter stop working.
it happened to me that my car stopped working and all i hear was click. i had a spare starter laying so i just went ahead replaced it. 30 min job. and it started
Old 10-16-2011, 11:44 AM   #9
Def
Check the nub on your clutch pedal that presses the clutch safety switch, it's probably gone. 99% sure that's your problem.
DEFSPORT
Old 10-16-2011, 02:24 PM   #10
wangan_cruiser
kouki man
Trader Rating: (36)
if this gone out. you wont even hear a clicking sound under the air box.
his clicks though
Old 10-16-2011, 03:06 PM   #11
Def
his clicks though
I think you are just hearing ignition on relays clicking. You can always check the starter signal wire to see if you're getting 12V to that with a test light.
DEFSPORT
Old 10-16-2011, 04:50 PM   #12
trainkiller
trainkiller is an unknown quantity at this point
1) check to see if anything is loose, if so tighten.
2) check voltage.
3) check all fuses inside the car. who knows you could stumble upon something.
Ricers are just people who have bodykits without being HELLAFLUSH bruh.
trainkiller is offline   Reply With Quote
Old 10-16-2011, 11:48 AM   #13
doitsidewayz
doitsidewayz's Avatar
doitsidewayz is an unknown quantity at this point
check main relay!!!
keep us updated dude. im pretty sure is going to be it
doitsidewayz is offline   Reply With Quote
Old 10-16-2011, 12:23 PM   #14
project_silvia
project_silvia is an unknown quantity at this point
check your battery terminals for corosion and check your starter
project_silvia is offline   Reply With Quote
Old 10-16-2011, 02:38 PM   #15
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Starter signal wire came off. Or ur terminals are corroded
SLiDe_WaYz is offline   Reply With Quote
Old 10-16-2011, 04:58 PM   #16
lost240soul
lost240soul's Avatar
lost240soul is on the path to ruinlost240soul is on the path to ruinlost240soul is on the path to ruin
i just had the same issue..i turned the key all i heard was the click and every now and then a small turn of the engine.. pull your starter off take it to autozone pepboys what ever have it checked guarantee its bad, takes no more than 15mins to pull your starter off and like 5 mins to test it
lost240soul is offline   Reply With Quote
Old 10-16-2011, 05:06 PM   #17
280zx2by2
280zx2by2's Avatar
280zx2by2 is an unknown quantity at this point
Voltage means nothing. Take your battery to an Advance Auto, Orileys, something like that. They can (for free) properly test for Cold Cranking Amps (CCA) Aka: what you really need to turn your engine over.
You would not believe the amount of batteries I see that are at 12.6v but are only at 100 or less CCA.
280zx2by2 is offline   Reply With Quote
Old 06-22-2014, 03:34 PM   #18
sarciel
sarciel is an unknown quantity at this point
ok so i'm not sure if this thread is dead but i need help and don't want to start a new one so here goes:
i have a 91 fastback s13 that i pulled the KA out of and put an SR into. i put in a new lower and upper wire harness from wiring specialties and plugged them in to see if the new engine would at least turn over and nothing.
i haven't plugged in any of the emissions plugs because i've gotten rid of all of them, i haven't plugged in any of the coolant hoses or vacuum tubes either as this is just to see if the new engine would crank.
battery's new, had the starter tested, everything looks to be in order but when i turn the key: nada.
my question is what the hell do i do now?
sarciel is offline   Reply With Quote
Old 11-05-2017, 01:45 PM   #19
Manie
Manie can only hope to improve
240 wont start
Im new to the 240s i own a 300zx and i bought a project vert 240 and wont start i hear clicking from the fuses in the engine bay when i try starting it does any one have ideas why?
Manie is offline   Reply With Quote
Old 11-05-2017, 04:50 PM   #20
shaggy sr
shaggy sr's Avatar
shaggy sr is an unknown quantity at this point
try to jumper an engine to body ground wire and start it up.
shaggy sr is offline   Reply With Quote
Old 11-06-2017, 01:58 PM   #21
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
+1 the little black signal wire
The Game
you lose haha
kyral is offline   Reply With Quote
Old 11-06-2017, 02:54 PM   #22
koukizhang
koukizhang's Avatar
koukizhang is on a distinguished road
Signal wires were the problem when my shit wouldn't start either.
koukizhang is offline   Reply With Quote
