Old 11-22-2011, 03:40 PM   #1
Lonesk8er
Lonesk8er is an unknown quantity at this point
Need some help
OK I have a 91 coupe 240 with a sr20, I had to replace my heater core witch I did, then wile I was hooking up the gauge cluster I saw that my clock wasn't working so I found that it was a bad fuse ok. Now my cluster is flashing. I tryed to start my car to move it out of the way, now my car is dead in the water. no clicks no nothing. WTF is going on here...
Lonesk8er is offline   Reply With Quote
Old 11-22-2011, 05:12 PM   #2
nissanfreak317
nissanfreak317's Avatar
Trader Rating: (18)
nissanfreak317 is an unknown quantity at this point
Feedback Score: 18 reviews
Dear sir, we care deeply for your situation and feel your pain.
We will, however, need more information about your situation before we can diagnose the problem.
We are the internet, not fracking psychics.
Did your car run before you did the heater core?
Is your battery fully charged and properly grounded?
are all of your fuses good?
What else did you take apart when you replaced the heater core?
Please get back to us on these pressing matters.
nissanfreak317 is offline   Reply With Quote
Old 11-22-2011, 08:12 PM   #3
Lonesk8er
Yes the car ran like a champ.
Yes my battery is charged and grounded right.
I had one bad fuse but I replace it.
And all i did was pull the dash and pull the gauge cluster in order to pull the heater core.
And I did see that when I hook up the battery Im seeing on the cluster that the check engine light is light up thats with the key out.
Ive check the grounds every where and ive check my relays...
Old 11-23-2011, 11:04 AM   #4
Lonesk8er
**update** I was able to start my car it was the clutch button that need to be engaged in order to start the car, but im still fighting with the gauge cluster, the rpm's are kinda working the needle is going crazy, every thing else is out/ not working. The fuel gauge is reading full. wile the car is off the engine light is kinda on, no dumb lights are coming on before i start my car...
