Old 12-12-2011, 10:03 PM   #1
Sideways_blksr20
Sideways_blksr20's Avatar
Trader Rating: (38)
Sideways_blksr20 is an unknown quantity at this point
Feedback Score: 38 reviews
Send a message via MSN to Sideways_blksr20
N1 rb26 failure
I dont know what i did wrong , i replaced my 26 water pump with a brand new rb25 n1 water pump.. Started the car and its spraying coolant likecrazy..
I know rb25 pumps and 26's r the same.
Any help guys
Sideways_blksr20 is offline   Reply With Quote
Old 12-12-2011, 10:11 PM   #2
memphis180sx
memphis180sx is an unknown quantity at this point
Is it spraying out of the waterpump?
memphis180sx is offline   Reply With Quote
Old 12-12-2011, 10:16 PM   #3
Sideways_blksr20
Trader Rating: (38)
Yeah ....
Old 12-12-2011, 10:23 PM   #4
GRNxS14
GRNxS14 is an unknown quantity at this point
Not to insult your intelligence, but you did use gasket maker to seal it up correct? Where exactly is the water spraying out of?
RB26 S14 Kouki
GRNxS14 is offline   Reply With Quote
Old 12-12-2011, 10:36 PM   #5
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
Yeah there's no oblong bolt hole in you block BUT that the upgraded N1 water pump has one, and it open to your cooling system. you'll have to weld it or seal it up.. its common
Chrischeezer is offline   Reply With Quote
Old 12-12-2011, 10:42 PM   #6
Sideways_blksr20
Trader Rating: (38)
Damn can i just weld it without taking it out it is coming right from there .
Old 12-12-2011, 10:43 PM   #7
Sideways_blksr20
Trader Rating: (38)
Yeah i did bro but ididnt know u were supposed to weld that hole ...
Old 12-12-2011, 10:48 PM   #8
Chrischeezer
I wouldn't do this but...
I have read that most ppl fill the whole with silicone as its a very small part not sealed.
read up on it,
Old 12-12-2011, 10:52 PM   #9
Chrischeezer
its gross but it works
Old 12-12-2011, 11:09 PM   #10
Sideways_blksr20
Trader Rating: (38)
So i dontneed to remove the whole pump ? Just fill the hole with rtv and put back the bolt with a washer ?
Old 12-13-2011, 12:22 AM   #11
silver350z05rb
silver350z05rb is an unknown quantity at this point
yea its common like they said, i have heard of doing both, silicone the shit out of it or weld it as well, i would assume welding it shut would be better?correct? i mean im sure its about than $10 bucks for someone to weld that for you. or Free if you have a machine.
silver350z05rb is offline   Reply With Quote
Old 12-13-2011, 09:47 AM   #12
Sideways_blksr20
Trader Rating: (38)
So should i just remove the one bolt fill it up with rtv and put back the bolt with a washer?
Old 12-13-2011, 09:49 AM   #13
mattack69
mattack69's Avatar
mattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enough
Send a message via AIM to mattack69 Send a message via MSN to mattack69 Send a message via Yahoo to mattack69
Weld this, do it right the first time. Those aren't cheap if they fail.
mattack69 is offline   Reply With Quote
Old 12-13-2011, 09:56 AM   #14
Sideways_blksr20
Trader Rating: (38)
So weld it an redrill it ?
Old 12-13-2011, 10:24 AM   #15
mattack69
mattack69's Avatar
Have it welded then retap yes. That's my vote at least. Should be fairly easy
Old 12-13-2011, 11:05 AM   #16
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
i had 2 rb26 with N1 pump !!!! all my bolt were in place except for that one your talking about !!! put alot of RTV in the oval hole and insert bolt bolt with washer !!!
never leaked any coolant
i used the orange RTV that came in my rebuilt gasket kit !!!
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 12-13-2011, 11:20 AM   #17
rbs14kouki
rbs14kouki's Avatar
If you dont want to remove the pump ! Make sure you dry everything cause the Rtv wont stick good
AV FABRICATION
Old 12-13-2011, 12:19 PM   #18
Chrischeezer
use "Ultra Gray" silicone too.. it dries much harder.
just bragging : my R34 engine doesn't have this problem
Old 12-13-2011, 02:50 PM   #19
Sideways_blksr20
Trader Rating: (38)
Thank u guys
