Old 01-17-2012, 10:35 AM   #1
Paper_Tiger240
Paper_Tiger240's Avatar
Paper_Tiger240 is an unknown quantity at this point
SR Chasebays boost solenoid
I recently bought chasebaysonline's electronic boost solenoid and i am having difficulty trying to install it
My main problem is what do I splice the boost solenoid too?
I have a Apexi power FC for sr20det redtop
Before I bought the product I contacted chasebaysonline and they said it works with the power FC
Boost solenoid has two main wires: power and negativr
Any type of help will be appreciated
Call or text if you want
562.536.3904
Paper_Tiger240 is offline   Reply With Quote
Old 01-17-2012, 11:54 AM   #2
cotbu
cotbu's Avatar
Do you have a 5pin port or 3pin port on your power fc?
Old 01-17-2012, 12:01 PM   #3
gunmetalr32
gunmetalr32's Avatar
gunmetalr32 is on a distinguished road
I was thinking on getting this for my power fc too let its know how it works out
gunmetalr32 is offline   Reply With Quote
Old 01-17-2012, 12:40 PM   #4
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
yes im interested how this would work on power fc. i have a power fc too for redtop lol
Old 01-17-2012, 01:07 PM   #5
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
Call me stupid, but have you called Chase and asked him what to connect it to?
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 01-17-2012, 01:13 PM   #6
N2HIFI
N2HIFI is an unknown quantity at this point
This, common sense is so underated sometimes
N2HIFI is offline   Reply With Quote
Old 01-17-2012, 01:59 PM   #7
OLDSCHOOLRICE
OLDSCHOOLRICE's Avatar
OLDSCHOOLRICE is an unknown quantity at this point
The solenoid you purchased is universal. Technically it should work with any single solenoid electronic boost controller. As in if the solenoid on your EBC takes a poop you can wire in the Chasebays solenoid as a replacement piece.
As far as running it off of your power fc, you would have to look up the wiring to see how to run it as well as wiring up a pressure sensor.
If you look at the Power FC Boost Controler Kit you save yourself the above mentioned nonsense. Wiring, with the proper connectors, and I imagine there's instructions on how to connect it properly.
Apexi 415-A013 Power FC Boost Controller Kit Add-on
OLDSCHOOLRICE is offline   Reply With Quote
Old 01-18-2012, 07:24 AM   #8
Chase Bays
Chase Bays's Avatar
Chase Bays is an unknown quantity at this point
Our Boost Solenoid has a Deutsch connector for easy disconnect and is loomed like our engine harnesses. Thus an already great looking item that our customers only have to hook up to 12v and pin at the ECU. Its meant to be a replacement or add on for boost by gear.
On our kit the Red wire goes to switched 12v source and the White/Green wire goes to Pin 111 on S13 SR20DET 64P ECU connector.
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE
www.ChaseBays.com | [email protected] | (205)623-2188
Chase Bays is offline   Reply With Quote
Old 01-18-2012, 07:34 AM   #9
Chase Bays
Chase Bays's Avatar
Just read some of the posts. It seems to me that all you need to so is convert to Speed Density. That pressure sensor is a MAP sensor, same thing. You can use any MAP/Pressure sensor. Don't buy that $349.99 kit, you already have half of that. Do you have a L Jetro or D Jetro Apexi? Post the part # if you're unsure.
