![]() Join Date: Feb 2010
when it is stuck down is the car still in neutral or does it release the pressure and engage if not?
if you push it and it staying engaged check the clutch pedal assembly it might be binding if not replace your slave and master its like $25 bucks total at an auto parts store.
S13 Coupe, S14 Kouki Crew Chief jeff Jones Racing |
i paid 26 bucks for my clutch master cylinder. i don`t know any place that sells slave and master cylinder for 25 bucks. but yeah, check those. if the fluid is really dark or its empty, you`ll need em. also, don`t be surprised if you need both the master and the slave cylinders at the same time.
I had a similar problem, I would have to move it back up with my foot lol ... I checked it all out and it was the mc it was leaking past the firewall into the car. I swapped the mc and it fixed my problem. Check your level if it's changing you got a leak
![]() I have five speed bolts if you need any Custom 2+2 E brake Cable brackets sold here!!!!! ![]() ![]() |
How about we try bleeding the clutch before throwing parts at it? Verify that something is bad, before replacing all of them. Remove the clutch damper and rebleed... Then come back with more information.
