![]() I installed a new spec stage 3 clutch kit and throw out bearing and a nismo flywheel . i bleed my clutch slave cylinder and adjusted my push rod on the clutch master cylinder. when the car is off it goes into gears but when its on it doesnt when i hit the clutch pedal i hear a weird sound like the throw out bearing hitting the pressure plate. the clutch fork seems to be actuating fine when i press the clutch pedal what can it be.
![]() Join Date: Jan 2003
![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Not to be insulting, but did you put the throw out bearing in the right way. Its sounds like its backwards. There are a bunch of threads on here that had the same problem, and that's what it was. Take it apart and check, it will F-up your clutch and possibly your flywheel.
![]() Join Date: Jan 2007
ive done this before, forgot what it was but take the trans back out and check around
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
