help please!!!tail light dont work
so i got a 93 240sx coupe the rear tailights worked ffine but after a while they didnt work as they should......they stay on and dont flash when i step on the break...
Check the sensor on the brake pedal. It's like a buton that touch the ''arm'' of the brake pedal. It should bump against a rubber plug. If nothing touches it (like there's a hole where the sensor button is) then your rubber plug broke.
#6 | |
Same thing happened to me, I have some info here: Brakelights don’t work – why? |
There is a rubber bumper mounted on the brake pedal that actuates the switch. Over the years, the rubber will dry out and the bumper can fall out, leaving nothing to press on the switch.
#8 | ||
And here's what you want to buy http://www.ebay.com/itm/Green-Brake-...r#ht_500wt_922 |
![]() Join Date: Nov 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
www.240SXTECHDVDS.org Home Page has FSM's specific for your car so you can track the wires.
KA-T ![]() |
Just wanted to say that in my write-up, I used one of those plastic interior plugs as a substitute.
I thought it would be a stop gap, but it's worked AMAZINGLY well. I'm in the middle of rebuilding my car, had the dash and steering column out and the plug has no markings on it whatsoever, completely fine. I'm leaving it in, no sense fixing it if it ain't broke. EDIT: This is going on 18 months since I replaced the plug. |
Can any one tell me y there would be a brown and orangish cable hooked up to my fuses....I think there audio but that's what caused the lights to go out....ohhh and I guess the previous owners had the same problem because there where a lot of fuses and a couple of plugs in the ashtray
#14 |
#15 |
Tags |
coupe taillights, coupes, taillight lights problem |
