Old 03-07-2012, 09:25 PM   #1
ardeine
ardeine is an unknown quantity at this point
s14 95 240sx ide problem. wont stay on. throwing codes # 24, 41, 84
so i have a 95 240sx ka24de and im trying to find out the reason why the car wont stay running. i checked the codes on the ecu and it gave me codes # 24, 41 and 84
if anybody knows howe i can fix this problem please let me know. thanks!
ardeine is offline   Reply With Quote
Old 03-08-2012, 09:44 AM   #2
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
Couldn't find anything but for your code 41 which is the air intake temp sensor.
Could you further elaborate on how your car is acting.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 03-09-2012, 03:35 AM   #3
ardeine
car has idles fine when its cold and as it starts to warm up, the car tends to die on me. i found one of the other codes and it said somethings wrong with my iacv. (idle air control valve)
do you know how i can fix the iacv?
i have a short ram intake on the car and i cant seem to find any air intake temp sensor.
much help needed if you can guide me what to do that would be great.
my cluster seems to not work either ever since i swapped the motor.
in the fuse box under the hood i have a fuse thats grey and it says 75a on it and on the cover it says for fl. does anyone know what this is for? could it cause my cluster to not work??
Old 03-09-2012, 03:52 AM   #4
tre4s13
tre4s13 is an unknown quantity at this point
Send a message via AIM to tre4s13 Send a message via Yahoo to tre4s13
What did you swap to? SR? Did you use n60/n62/g60/cobra maf? You can delete the IAV, so it couldn't be that. The iacv is possible.
Sent from my LG-P999 using Tapatalk
tre4s13 is offline   Reply With Quote
Old 03-09-2012, 03:53 AM   #5
ardeine
heres the pic of what fuse is popped. can this cause my cluster to not work?
Old 03-09-2012, 03:53 AM   #6
tre4s13
IAT*
Old 03-09-2012, 03:54 AM   #7
ardeine
i swapped a bad ka to another ka24de with 90xxx miles on it
Old 03-09-2012, 05:14 AM   #8
tre4s13
Code 24 doesn't exist (check the flashes again)
41 is iat
84 is automatic transmission communications line.
Pretty sure its your first code. Recheck that shit bruh. As far as the fuses go, I'm str8 s13. I do know a big 75 is for the alternator on the s13, irc.
http://bc240.com/index.php?showtopic=608
Old 03-10-2012, 03:02 AM   #9
ardeine
i have a feeling it could be my aicv since thats one of the codes. and that fuse i went to the junkyard and got that and spares. yes i believe its for the alternator also. ill check it out tomorrow after work. thanks for the help friends!
Old 03-10-2012, 04:02 AM   #10
tre4s13
I don't remember you mentioning the iaccoca's throwing a code. But that will fudge up your idle. GL.
Old 03-10-2012, 07:31 AM   #11
laurentj23
laurentj23's Avatar
laurentj23 is an unknown quantity at this point
How do you pull the codes out without taking the ecu?
'Born Ready!',LJ
laurentj23 is offline   Reply With Quote
Old 03-10-2012, 09:39 PM   #12
Pro ViZIon
Pro ViZIon's Avatar
I guess with a consult tool. But it's not very hard to get to or do.
To OP, have you tried adjusting your tps?
Old 03-11-2012, 07:18 PM   #13
ardeine
yeah if i move the tps any direction it would die
it idles under 1000 and just dies when it warms up
Old 02-06-2013, 03:34 PM   #14
misterdumby
misterdumby is an unknown quantity at this point
mines doing the same thing
misterdumby is offline   Reply With Quote
