SR20DET Throw out bearing holder?
Ok so I ordered a new clutch because my throw out bearing and everything blew up, literally the throw out bearing holder exploded and is in pieces on my garage floor. I pulled my trans off today and found that. I ordered a new clutch with all the bearings, but I need the bearing holder for the red top sr20, I don't know what part number or anything to look for, I know that people would have the part number for the bearing but not the holder. Can anyone help me out here? Thanks
Not sure on the part number, but it is called the Clutch Release Sleeve.
Here is a link to the one for a KA24DE... SLEEVE-CLUTCH RELEASE - 240SX (S13) :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com I don't think it is compatible with the SR20DET, although I'm not 100%.
Ok well I got that bearing and everything pressed it in the throw out bearing, but there is no way this is right. My transmission output shaft looks like it is to small or something cause this doesn't not fit right at all.
Man w/ CTSV & a Car Seat
It shouldnt be sitting on the output shaft itself, its should be sitting against the back. Take a picture and post it up just to see. For the most part, nissan uses the same size carriers for almost all their transmission, only thing that changes is the thickness.
Hmm I think I figured it out what it is, The front cover on the transmission that has the sleeve that covers part of the output shaft that the tob sits on is broken off -.- whoever had it before me I had no clue. They put the transmission on there without even bothering to fix it, how it ran beats me now. Because if it was on the tranny before I pulled the transmission I think I would've found metal all in the bell housing. I ordered a new front cover.. How do I got about installing the oil seal that is on the front cover? Thats one thing I've never done is changed an oil seal on a transmission before just press it in?
