Discussion: OEM vs. aftermarket sways
I have the opportunity to purchase a set of OEM SE sways for an S14. I'm trying to compare these between the suspension tech sways. Some ppl onNICO recommends OEM sways over aftermarket sways, point being that they overwhel street tires. What's your take on this?
![]() Join Date: Jan 2003
I would go for the rear one but leave your stock front one on. The rear aftermarkets a quite a bit bigger but the fronts are comparable.
96' SE Turbo'd Super 60, S-AFC, SMIC, 370cc Injectors, Open Air BOV, Warblo 255 pump, Stage 3 Clutch Kyb agx, Sportline Springs Full body kit, Bomex rear, Drift sides, r34 front gunmetal rims, yok tires |
#4 | |
Autox Technician
![]() Join Date: Dec 2001
FWIW: i like my whiteline bars, even with the bushing style endlinks they came with. can't wait to get the tie rod endlinks in and make a solid endlinks.
#5 | |
A solid bar is only about 5% stiffer than a hollow bar of the same diameter... a properly sized hollow bar can be as stiff as a solid bar and alot lighter. Most aftermarket bars are not hollow though, I only know of the arc pipe stablizers from Japan, and those cost $$$
![]() We are developing lower cost solid endlinks for the Z32, they should work with adjustable (spade-end type) sway bars for the 240SX... Quote:
#7 | |
#8 | |
In torsion, the center of the bar contributes little to the torque, as it has no leverage (radius from axis of rotation). That is why a solid bar is only a little better than a hollow bar of the same diameter, for torsion. For bending, actually I believe a hollow bar is much easier to bend than a solid bar...
Link to some info on the subject: http://www.hotchkis.net/pdf_files/HollowSwayTech-D.pdf Quote:
you know I was thinking about that, but when I weighed my front white lines against my front stock, they are roughly the same. Then again that was on an s13 as well.
On mine the rear was quite a bit bigger, there was apsolutly no comparison. but I really didn't feel like the front was a good replacement for the money, Keep in mind that this was also on an s13, I have only glanced at the one on my s14 and it appears to be about the same as the one on my s13, Then again I do not have a clue what the previouse owner had upgraded.
#15 |
The only aftermarket sways in my price range are the whitelines and suspension techniques. I'm leaning towards more to the STs because of the price. Of course there's always the option of OEM sways, since I have the opportunity now to buy a set for nearly 1/2 the price of the STs.
#17 | |
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink. |
#18 |
![]() Join Date: Sep 2003
go with a beefier rear sway bar whatever the brand. I got whiteline adjustable. I heard the ST rears dont fit right. Can anyone confirm? anyways that's one answer to your question. anything more specific you want to know?
Hi |
#19 |
![]() Join Date: Mar 2002
If you wanna be cheap buy a JDM rear bar, go for well under $100 shipped. Or go to a junker and hope to find an S13 with HICAS.
For S14 owners, not sure if the JDM HICAS rear bar is any bigger.
PROCEED Grip Gambler |
#20 |
i got whiteline rears on full stiff, stripped interior with an open diff. I have 205-50-15 azenis and i have a hard time burning out. Good tires will fix that problem.
More importantly, unless your are drag racing for et's or pinkslips, or auto-x for some ppl, it's kinda pointless to associate any negative affects anything will have on your launch. I think the handling characteristics of a stiff rear sway bar far outweigh the traction problems that i didnt even notice. as far as powering out of turns, maybe you'll spin a crappy tire, but the azenis you'll only spin in 1st gear. Plus it's ok if the inside tire spins a little, at least you're not understeering as much.
Hi |
#21 | |
#22 |
thanks for all the great replies. I'm hoping that once I put my AGX/RSR on the body roll would be reduced by alot. Replicant you are in ATL? Me too. I've seen your car on the 240s over atlanta site before.
Anyway I've searched all over but I cannot find the stock S14 sway bar sizes both SE and standardn. I think I saw a thread about this recently but I just can't see to find it. |
